tripodtiger
Australian RD/RZ Owners Register
Post by tripodtiger on Sept 3, 2014 1:29:55 GMT 1
Currently considering exhaust gas analyzers. Lambda sensor thingys. Essentially to help fine tuning on the race bike. I suspect it may be cheaper than the re-bore / new piston & ring kit route in the long run. Does anyone have any knowledge? This is as far as I've got. There is an Australian made one Easitune www.easitune.com/The Easitune kit is designed for karts. I have seen it fitted to an LC. and Accumix EGT kit. reading their information on the below page, it doesn't suggest it is anything other than a pair of temperature gauges. www.accu-products.com/accu-products-specialties/dual-probe-egt-kit/prod_3013.htmlanyone know of other kits?
Post by slinger on Sept 3, 2014 13:46:51 GMT 1
IMO EGT is the way to go for consistent readings on two strokes, once you have confirmed the temps on a loaded dyno you can up jet,down jet change the ignition and see which is the right direction.
tripodtiger
Post by tripodtiger on Sept 4, 2014 2:26:28 GMT 1
Thanks Slinger.
I suspected that temp was a fairly good indication of combustion. How do I get a base line exhaust temp? No access to a dyno. By the time I get back to the pits for the thermometer, the temps are gone. Reading plugs is a black art, and doing a plug chop on a track day or practice is a practical issue. I need to do more riding and data collection too.
A mechanic mate reminded me that the analysers they use in workshops cost several grand. The analyser that fits to the bike is a few hundred. On the flip side of that, just because it's 'cheap' doesn't mean it's nasty or not reliable.
I fully realise that both options are a tuning aid, not a tuning kit.
Trying to get the bike to a dyno is somewhat problematic for me. I have a couple of hundred kay drive to any race track and further to any specialist bike dyno. And I'm not trying to win races. I just want to make sure I don't burn pistons etc whilst having as much fun as I can. Do as well as I can with the bike that I've got.
I'll speak with the easitune man and see what he reckons.
Anybody else with something to add?
Post by slinger on Sept 4, 2014 12:18:31 GMT 1
If you had access to a dyno you could do a load and hold run and read the hydro-carbons then cross reference to your EGT readings, my EGT would read 600*c and the engine would be a little on the lean side. So I would set mine up to 570/580*c on the track for that given day which worked well for me.
tripodtiger
Post by tripodtiger on Sept 5, 2014 5:31:36 GMT 1
If you had access to a dyno you could do a load and hold run and read the hydro-carbons then cross reference to your EGT readings, my EGT would read 600*c and the engine would be a little on the lean side. So I would set mine up to 570/580*c on the track for that given day which worked well for me. Just looked at your facebook page. Choice!
