Post by powellm976 on Sept 2, 2014 11:29:46 GMT 1
No not the theft kind I've recently bought a yammagamma and the stator wiring gets really hot just after the first connector block. So hot i think it would be a problem if I were to leave it, any ideas what to check? is there somewhere to download a manual for the ypvs? cheers matt
Post by muttsnuts on Sept 2, 2014 11:46:59 GMT 1
check the white connector block - the one that the white wires go into - these are your charging wires, these corrode/get badly worn nd melted at times, if any signs of melting.getting hot you can either try and clean them all up and tighten the actual connectors themselves, or swap it for a spade connector block which tends to give it better connectivity and surface area for the terminals to use, so keeps it cooler
HTH
Post by copper99 on Sept 2, 2014 19:38:45 GMT 1
Hello mate...where abouts in the country are you? Ive just bought one as well, maybe we can compare notes..
Post by powellm976 on Sept 2, 2014 23:42:18 GMT 1
Thanks. Will try changing that connector. I'm in Perth Australia by the way
Post by greasemeup on Sept 3, 2014 9:26:08 GMT 1
Check out the PSB forum for a local that is willing to offer some help?
Sent from my iPhone using Tapatalk
Post by mikee on Sept 3, 2014 16:07:36 GMT 1
Sounds like resistance in the connector , corrosion ,like wot dave said ^
Mike
Post by copper99 on Sept 3, 2014 18:29:26 GMT 1
Thanks. Will try changing that connector. I'm in Perth Australia by the way Only 9.026 miles from me...ill be over for a cuppa in a bit..any pics of the YamaGamma?
Post by powellm976 on Sept 4, 2014 12:30:28 GMT 1
No pics yet but will try to get some over the weekend
