Post by flatspot on Aug 29, 2014 21:08:46 GMT 1
So I need some new petrol pipe but everything I see 6mm ID has a huge OD. Stuff I have on at the moment had a nice small OD. Where can I get this type? I think I originally bought it from Yam when I was young and stupid with money to burn
Post by marsbar350 on Aug 29, 2014 21:23:15 GMT 1
any pipe you buy now wont last long with the ethanol content nowadays i change mine every season
horace
Post by horace on Aug 29, 2014 21:52:07 GMT 1
Never changed any of mine in years best have a look at it.
Post by nikfubar on Aug 29, 2014 21:56:58 GMT 1
Post by LC_BOTT on Aug 30, 2014 7:27:38 GMT 1
You could try fleabay and search for nitrile pipe, but I'd probably go for the above Tygon stuff is supposed to be good as well, but it's a bit harder to get hold of, RC model cars etc, use it a lot.
Post by muttsnuts on Aug 30, 2014 9:29:40 GMT 1
I use the ariete pipe now, its as good as anything out there at the moment and has a nice size to it, not cheap, but better than other stuff I've tried and I have tried them all ! - Tygon is good as well, but only mamnaged to get hold of a small amount and that's been used a long time back now
Post by flatspot on Aug 30, 2014 10:08:14 GMT 1
Righto thx chaps, I'll get some ordered.
Post by reggieperrin on Aug 30, 2014 11:19:09 GMT 1
Tygon is available in 2 sizes from decent RC hobby outlets. You can buy it off the roll by the metre. It won't be effected by the ethanol at all. Unfortunately, even the larger sizer isn't big enough for petrol supply pipes but it's great for overflows and oil feeds etc.
Bizarrely, it was originally developed as an insulator for fibre optic cable that was to be laid under the sea...
Post by oldelsieboy on Aug 30, 2014 13:00:00 GMT 1
I originally bought it from Yam when I was young and stupid with money to burn You'll be surprised how cheap it is. 1.5 metres x 8mm O/D x 5mm I/D = £4.50 (ish) OEB
artie
Post by artie on Aug 30, 2014 14:18:03 GMT 1
any pipe you buy now wont last long with the ethanol content nowadays i change mine every season This was mine after eighteen months
Post by hampo on Aug 30, 2014 20:45:09 GMT 1
I've used tygon for the pipes after the T piece on my valve, and for the power jet pipes where it gives a quick 'n' easy fuel level check. Been on 2 yrs & still good. I tried it on the tap - T piece section but it kinks really easily, didn't use it on oil tank-pump for the same reason.
Post by flatspot on Aug 30, 2014 23:35:54 GMT 1
The stuff I have on the bike is not really a flexible rubber. It reminds me of more of a nylon type of material but with more flex. After all these years it's only split a bit where it's pushed onto the tap. The rest of the pipe is not degraded.
Post by andrew on Sept 3, 2014 16:45:13 GMT 1
I got some gen yam stuff (intended for boats really) but was exactly the same dims as the old stuff, will post the link this evening if you need it
Post by rider4life on Sept 3, 2014 17:26:25 GMT 1
need some aswell andrew post link if you can
Post by stusco on Sept 3, 2014 18:39:45 GMT 1
So is the samco fuel pipe not any good
Post by andrew on Sept 3, 2014 19:30:24 GMT 1
Post by flatspot on Sept 7, 2014 19:49:30 GMT 1
^^^^ That stuff is 11mm OD, the pipe I have on is 7mm OD which looks a lot better. Looks like I'm gonna get stung from Fowlers again. More in postage than parts !!
Post by oldelsieboy on Sept 7, 2014 19:52:22 GMT 1
Looks like I'm gonna get stung from Fowlers again. More in postage than parts !! Again you may be surprised, my last order placed at 5.20pm on Wednesday afternoon was delivered by UK Mail courier the next day at a cost of £3.30 OEB
