Post by tommyc**kles1970 on Aug 28, 2014 22:38:48 GMT 1
Indicators won't self cancel , changed out switch unit for another but still no luck . Anyone out there point to something I'm overlooking ? Cheers
Post by bare on Aug 29, 2014 2:45:35 GMT 1
Is the Relay/timer gizmo hidden behind the headstock healthy?
Post by tommyc**kles1970 on Aug 29, 2014 10:23:05 GMT 1
changed the unit behind the head stock no idea how to test I suppose they both could be duds ? Anything else I'm over looking ?
Post by oldelsieboy on Aug 29, 2014 10:49:42 GMT 1
changed the unit behind the head stock no idea how to test I suppose they both could be duds ? Anything else I'm over looking ? Do you have an original 3 pin or pattern 2 pin indicator relay? OEB
Post by andrew on Aug 29, 2014 17:18:47 GMT 1
Mate. I've had allsorts of electrical issues, especially with the indicators. basically its their age! makes sure before you head off to eBay that you've taken all connector's off, cleaned as much as possible and squirt some WD in. I thought I needed to purchase loads, turned out time and care is all that's required.
Post by kostas on Aug 29, 2014 18:12:17 GMT 1
I had my loom put on the side while rebuilding my bike and after reconnecting it nothing worked!!
Turns out almost 2 years on the shelf crated a fine film of corrosion on the connectors. I cleaned it up with with contact cleaner everything came back to life.
Kostas
Post by yamark on Aug 30, 2014 9:55:11 GMT 1
The self cancelling unit is usually quite reliable. It's a timer but is also controlled by the reed switch in the speedo so check wires/connections there. From memory the timer and distance counter[reed switch] must both elapse to cancel the indicators.
HTH Regards Mark
Post by hampo on Aug 30, 2014 20:50:38 GMT 1
When my cancelling unit went west the indicators came on & stayed on with no flash, disconnected it & all ok except of course no self cancel so I'd guess yours isn't receiving a signal from the reed switch. Do you really need the self cancel feature?
Post by tommyc**kles1970 on Sept 2, 2014 22:04:07 GMT 1
It's a three pin indicator relay Denso marked on it indicators work and cancel fine of indicator controls .Id just like it to work .There is one cable there a yellow with a green line not connected and I can't see any female point for it .
Post by oldelsieboy on Sept 2, 2014 22:09:15 GMT 1
It's a three pin indicator relay Denso marked on it indicators work and cancel fine of indicator controls .Id just like it to work .There is one cable there a yellow with a green line not connected and I can't see any female point for it . There is your problem, yellow/green lead from indicator relay plug will be connected to a black loom lead, disconnect this black lead & connect yellow/green that you have found unconnected. Leave black wire loose. OEB
Post by tommyc**kles1970 on Sept 2, 2014 22:42:54 GMT 1
no indicators at all then . thanks for you help
