Post by stusco on Aug 26, 2014 14:15:47 GMT 1
Just cleaned my rusty tank with citric acid ,did a great job ,trying to dry I out now any suggestions as how to stop the rust coming back?
Post by brownsauce on Aug 26, 2014 15:10:55 GMT 1
Ive used on my honda cbr tank , I gave it a good swill through with thinners then put duck oil in for a day or 2 its now got petrol in it with abit of 2 stroke oil inas im not ready to use it yet.
Post by midlifecrisisrd on Aug 26, 2014 16:14:29 GMT 1
Dump a whole tin of wd40 in it while still damp and swill around before emptying and drying with a heater.
After that always put 50ml of oil in every tank to stop future flash rust
Post by shane250 on Aug 26, 2014 16:37:14 GMT 1
stick some diesel in it.
Post by steeley on Aug 26, 2014 18:25:14 GMT 1
celli thinners with 2 stroke oil swilled round.that should keep the rust at bay.has worked on my rgv 250 tank.
Post by muttsnuts on Aug 26, 2014 19:10:53 GMT 1
I always use a gallon of Diesel as per my other post in another thread, swill it around and then drain, it keeps it from rusting and will cause no issues when you fill it with petrol......
Post by LC_BOTT on Aug 27, 2014 11:41:28 GMT 1
Coincidence, just did my tank too, did same as above, bit of thinners and then a petrol/oil mix, haven't finished cleaning it yet, so it will do til then, need to get some paint on the outside as well, as it was quite rusty.
Post by jmartin on Aug 27, 2014 13:23:53 GMT 1
Ok where do we get citric acid from. . . In bulk . . Well enough to do a tank ?
Post by Roofmonster on Aug 27, 2014 13:33:04 GMT 1
Ok where do we get citric acid from. . . In bulk . . Well enough to do a tank ? Anywhere that sells stuff for home brewing/wine making will sell citric acid.
Post by brownsauce on Aug 27, 2014 14:19:19 GMT 1
Ok where do we get citric acid from. . . In bulk . . Well enough to do a tank ? Amazon sells it about £10 more than enough for a tank.
Post by stusco on Aug 27, 2014 14:44:25 GMT 1
I got mine of eBay paid a tenner for a kilo just put in my watering can with warm water filled the tank ,two days later nice and clean
Post by LC_BOTT on Aug 27, 2014 15:05:43 GMT 1
Here's a couple of pics of the semi-result, haven't finished it yet. It worked a bit faster than expected and I only had it in for a few hours, probably because it looked worse than it actually was. I used vinegar to do mine, it's done a couple so far, just store it on a big container out the way somewhere (cos it stinks Bought the rusty tank of jez (jmartin) in the for sale section a few days ago. Don't have the original pics yet, but.. Gave it a swish round with oil/petrol inside after I drained it, and a quick rub over with oil on the outside, as I've got to wire brush the mounts and a bit more underneath. Got a tiny dent on the top, but nothing leaks, and should be a mint tank like he mentioned in the ad, well pleased with the results. Probably going to naff it up with a home paint job when the time comes, going to throw some paint at it before the damp weather sets in.
Post by shane250 on Aug 27, 2014 16:03:34 GMT 1
Ok where do we get citric acid from. . . In bulk . . Well enough to do a tank ? Just use plain old vinegar.
Post by jmartin on Aug 27, 2014 16:09:33 GMT 1
Post by stusco on Aug 27, 2014 16:58:04 GMT 1
Does anyone use the tank sealer or am better to live with rust and filters
Post by shane250 on Aug 27, 2014 17:22:48 GMT 1
Does anyone use the tank sealer or am better to live with rust and filters No need to live with rust if you let vinegar do its work.
Post by shane2011 on Aug 27, 2014 20:47:12 GMT 1
Post by jmartin on Aug 27, 2014 21:22:16 GMT 1
Ok thanks for that . . .just ordered some, just had an lc in thats been standing for 5 years with the fuel in it, heavily stained inside the tank, dont look overly rusty though, but i want to clean the inside top of the fuel tank. See how it goes.
Post by steeley on Aug 28, 2014 5:26:19 GMT 1
buy a plastic dustbin and mix your citric acid up in it fill the bin up enough to cover the tank and give it a soak.i am on about the bare steel one it will clean up a treat.when done swill off with clean water and wipe round the out side with a scotch brite pad .swill out the inside,i used a gas paint stripper gun to dry the tank off.to stop the flash rust either thinners plus oil/diesel sounds good also.
