Post by jrsspool1 on Aug 25, 2014 15:53:52 GMT 1
Does anyone know if an LC2 p/v controller can be used on a 31k ypvs which is using a1ua cdi unit. If not, can anything be done to make it work. Thanks.
Post by markhoopy on Aug 25, 2014 16:30:59 GMT 1
The controller will work - just plug it in and off you go
Post by kostas on Aug 25, 2014 18:40:27 GMT 1
So are LC2, 31K and 1UA controllers the same?
I need one so good to know what to look for
Thanks
Kostas
Post by midlifecrisisrd on Aug 25, 2014 18:57:21 GMT 1
So are LC2, 31K and 1UA controllers the same? I need one so good to know what to look for Thanks Kostas Only difference is lc2 has a 3 way plug and others have a 2 way and a bullet. Lc2 has better openings Steve
Post by kostas on Aug 25, 2014 20:18:44 GMT 1
So are LC2, 31K and 1UA controllers the same? I need one so good to know what to look for Thanks Kostas Only difference is lc2 has a 3 way plug and others have a 2 way and a bullet. Lc2 has better openings Steve Thanks Steve, Kostas
Post by jrsspool1 on Aug 25, 2014 21:34:21 GMT 1
Thanks guys , this was for a friend , but both of us intend going down the zeeltronic combined cdi/pv route when funds allow ,do you think this is an even better route ?
Post by 4l04ever on Aug 25, 2014 21:41:09 GMT 1
Zeeltronic is best option, as fine tuning of power valves and ignition will help :-)
Post by jrsspool1 on Aug 26, 2014 10:30:06 GMT 1
Thanks
Post by kosaprasa on Aug 29, 2014 22:22:47 GMT 1
just for information, on rd 350 ypvs allso fit controler from TZR125 and TZR 250 ( 1kt-2ma ), this was teseted
Post by jrsspool1 on Aug 30, 2014 10:17:45 GMT 1
Thanks kosaprasa , noted
