horace
Post by horace on Jul 28, 2014 20:55:41 GMT 1
Hi, need to line a tank that's got rusty bits inside , it's solid and doesn't leak also has good paint on outside , but rust is always getting through into carbs and blocking up fuel filter, what's best kit to buy ? Cheers.
Post by gazlad on Jul 29, 2014 7:16:12 GMT 1
POR15 POR15 Motorcycle Fuel Bike Tank Repair Sealer Kit In stock: Ready to ship Product code: S215 Only £38.50 Quick Overview The POR-15 Motorcycle Tank Repair kit contains everything you need to repair and restore any small fuel tank.
Available from Frost.co.uk
Post by shane250 on Jul 29, 2014 7:16:28 GMT 1
Fill it with vinegar for a couple of days,filter it and put it back in,revolted it till no rust left.tank will end up like new inside. Take petrol tap off put a bag over it and refit to protect it or fit a spare tap. Do a search...
Post by shane250 on Jul 29, 2014 7:19:14 GMT 1
Fill it with vinegar for a couple of days,filter it and put it back in,refiler it till no rust left.tank will end up like new inside. Take petrol tap off put a bag over it and refit to protect it or fit a spare tap. Do a search...
Post by steeley on Jul 29, 2014 7:50:41 GMT 1
citric acid solution will also clean the rust out.you can get the stuff off ebay.think homebrew shops sell it as well.when you have finished with the stuff it can go down the drain its also a descaler.
horace
Post by horace on Jul 29, 2014 20:23:49 GMT 1
Thanks guys, will have a go with the vinegar first then move onto the por15 if it doesn't come up clean , the hard part is getting it all tipped out again after it's done it's cleaning.
Post by shane250 on Jul 29, 2014 20:29:47 GMT 1
It will come out ok,u will have to filter a few times till no rust left but it will come up like new.
Post by mudguts on Jul 30, 2014 9:28:26 GMT 1
I used stones, vinegar and coke, kettle descaler then used Rustbusters Slosh kit, worked brill for a year, but knocked it with petrol filling nozzel a couple of times and a few bits lifted, no leaks, sort of lines the tank what looks like apoxy resin, did not ever dissolve or block any filters.
Post by johna on Jul 30, 2014 22:54:48 GMT 1
+1 for por 15 done a couple of tanks with no problems at all even with the rubbish in todays fuel.
horace
Post by horace on Jul 30, 2014 22:57:37 GMT 1
Have been told brick (acid) cleaner brings it up like new as well , tried some stones but spent the hours trying to get them out again ,
Post by lcyoungboy on Jul 30, 2014 23:20:17 GMT 1
Personally I would not line it unless it is really really bad..use vinegar as shane250 says..or if you are as a last resort..use por15 is probably the best..just follow instructions to the letter..and DONT use kreem..from past experience
Post by twostrokebrit on Jul 31, 2014 1:54:13 GMT 1
Personally I would not line it unless it is really really bad..use vinegar as shane250 says..or if you are as a last resort..use por15 is probably the best..just follow instructions to the letter..and DONT use kreem..from past experience +1 to that
horace
Post by horace on Jul 31, 2014 7:44:49 GMT 1
Vinigar is going in then ,will report the results when is had time to work, now to find a couple of gallon of finest malt.
Post by shane250 on Jul 31, 2014 15:15:18 GMT 1
you need to neutralize the vinegar pretty quick after you drain it.I filled mine with water then dried it and then stuck some 2 stroke oil in but the oil took some getting rid of so id probably go with a normal premix on the first tank full.
Post by shane250 on Jul 31, 2014 15:17:24 GMT 1
This was far from my first filter,it took loads of filtering to get rid of all the loose rust in the tank.
horace
Post by horace on Jul 31, 2014 17:33:35 GMT 1
Rite got 6 litres in there doing its stuff , will leave it over the weekend giving it a slosh around from time to time,what did you use to filter it through Shane?
Post by shane250 on Aug 1, 2014 5:18:37 GMT 1
T shirt's
horace
Post by horace on Aug 1, 2014 7:47:41 GMT 1
Ah great got loads of them.
Post by shane250 on Aug 1, 2014 17:44:45 GMT 1
get a tooth brush and give it a rub where you can.Dont forget to put it back after use though
Post by shane250 on Aug 1, 2014 17:46:27 GMT 1
I emptied it from the tank into a washing up bowl then filtered it back into the tank through the T shirt into a funnel.
