Post by stusco on Jul 16, 2014 16:28:35 GMT 1
Can anyone tell me how much play should be on the idle gear,mines wobbles about a bit and I'm not sure if this is right?
Post by Eyrey1 on Jul 16, 2014 16:42:23 GMT 1
shouldnt there be a washer/shim behind it ? is it there ?
Post by stusco on Jul 16, 2014 17:41:21 GMT 1
I'll take it off and check
Post by stusco on Jul 16, 2014 18:38:08 GMT 1
Took the idle gear off thrust washer is fitted so looks like it needs a new bush
Post by stusco on Jul 16, 2014 23:25:54 GMT 1
Mines worse than that
Post by stusco on Jul 17, 2014 14:09:50 GMT 1
My idle gear is knackered anyone know where I can get a new one?
Idle gear
Jul 17, 2014 20:41:57 GMT 1
via mobile
Post by midlifecrisisrd on Jul 17, 2014 20:41:57 GMT 1
My idle gear is knackered anyone know where I can get a new one? Norbo or still available from yam for about £48 I thought mine was not bad till I put a new one on and it had nearly no play Steve
Post by stusco on Jul 17, 2014 22:03:55 GMT 1
Great ill get one from norbo ,theres loads of play and wobble the gears are also damaged but the clutch basket and kickstart are unmarked which is strange,I measured the shaft it is 14.96 mm do guessing it used to be 15mm so a new one will do
Post by stusco on Jul 18, 2014 14:01:28 GMT 1
They want £35+vat and the teeth are chipped and worn so I'll just get a new one thanks for the advice anyway
Post by stusco on Jul 18, 2014 14:47:10 GMT 1
I thought it was steep they had me strip the shaft to send that as well before I found norbo sells them now I need circlips as well
