Post by looey on Jul 14, 2014 21:59:46 GMT 1
Ok, latest problem with my Hybrid after finally getting it running properly and sorting oil leaks etc.....IT NOW HAS A CHARGING PROBLEM !!! Battery only showing 13.5v at 2,000rpm with no lights on, and battery voltage actually drops at any revs with the lights on . Going to investigate further tomorrow, but already noticed that the wiring to the Reg/Rec is 4 individual female spades crimped onto the end of the loom, so would like to get that sorted by re-fitting the correct type of plug to the loom. Anyone by any chance have an old connector from a chopped/knackered loom I could buy to re-fit, or know where I could buy the correct type of plug to fit into an F2 Reg/Rec ?. Cheers
Post by rich on Jul 14, 2014 22:11:40 GMT 1
Andy, I have always run a 4L0/31K type reg/rec on my hybrid with an F2 stator and it works fine. They are heavily finned and a lot more robust than the F2 type. Easy to wire in too, just the 3 white wires, thick red, ground and a brown
Post by looey on Jul 14, 2014 22:33:14 GMT 1
Aahhhh, that's useful to know. If it turns out to be the reg/rec that's faulty, then maybe the 4L0/31K will be the way to go. The F2 type is only 4 wire isn't it ?, where do the other 2 wires come from ?...
Post by rich on Jul 14, 2014 22:46:16 GMT 1
I think the F2 reg/rec has three white wires plus a red. It must earth through it's body. The 4L0 has a black wire for earth, 3 whites, a red and a brown. Not quite sure what the brown wire is for but it connects to the fuse box so you could probably connect it to any brown as they are all common.
Post by oldelsieboy on Jul 15, 2014 17:00:33 GMT 1
Anyone by any chance have an old connector from a chopped/knackered loom I could buy to re-fit, This one? OEB
Post by looey on Jul 15, 2014 17:39:26 GMT 1
NICE Can I have it please ?
Post by oldelsieboy on Jul 15, 2014 17:50:35 GMT 1
NICE Can I have it please ? pm your address & I'll drop it off, as long as you're still a Surrey resident
Post by looey on Jul 15, 2014 17:54:45 GMT 1
Nice one, moochas
