horace
Post by horace on Jul 14, 2014 20:35:55 GMT 1
Any top tips on bearing removal seems tight in case, haven't attempted it yet but tempted to give it a tap. Thanks.
Post by stusco on Jul 14, 2014 20:58:31 GMT 1
Tapped mine out it was a nice fit just right
Post by soccersmyth on Jul 14, 2014 21:44:56 GMT 1
Warm the casing in the oven
Post by JonW on Jul 14, 2014 22:54:28 GMT 1
Even a heat gun will work, they are not that tight.
horace
Post by horace on Jul 15, 2014 20:44:04 GMT 1
Thanks for your help, poured a kettle full of boiling water over it and gave it a tap with a socket and out it poped, now to get the new one in when it arrives!
Post by steven on Jul 15, 2014 22:54:22 GMT 1
Hi Horace, If you want to put your new bearing in the freezer for a few hours before you fit it, you should find that it will go back in no probs. I also draw the new bearing in with these bits of plate and a long cap screw, as I find hammering a new bearing in most uncivilized and uncouth ! In practice, the water pump bearing knocks in and out no probs with a sutable drift or punch. steven.
Post by rsvr1000 on Feb 15, 2015 13:04:50 GMT 1
Does it matter which way round the seal fits in ?
Post by oldelsieboy on Feb 15, 2015 13:44:13 GMT 1
Does it matter which way round the seal fits in ? Yes OEB
Post by pistanbroke on Feb 15, 2015 14:59:48 GMT 1
Does it matter which way round the seal fits in ? Yes OEB Should have 'WATER SIDE' written on the bearing if you got a original Yam one.
Post by oldelsieboy on Feb 15, 2015 15:02:55 GMT 1
Should have 'WATER SIDE' written on the bearing SEAL if you got a original Yam one.
Post by steeley on Feb 16, 2015 12:29:02 GMT 1
steven hi,you have sure got a nice selection of specialist tools for the various jobs around these bikes.
Post by Tobyjugs on Feb 16, 2015 12:43:20 GMT 1
steven hi,you have sure got a nice selection of specialist tools for the various jobs around these bikes. Yeah i am a little envious of his special tools. I makes things so much easier
Post by pistanbroke on Feb 16, 2015 18:54:28 GMT 1
Should have 'WATER SIDE' written on the bearing SEAL if you got a original Yam one. whoops lol , thanks for correcting that one OEB
Post by shandyboy on Aug 9, 2016 17:58:38 GMT 1
Sorry to jump in on the thread, struggling to get bearing seal located, water side on seal facing the impeller cover ? its a genuine yam part but will not go past where the bearing locates ? seems like it sits in where the bearing should be ? any advice boys !!!!
Post by shandyboy on Aug 9, 2016 18:45:15 GMT 1
seems like the the seal has a metal outside housing the same size as bearing so will not compress into where it locates ?
Post by kostas on Aug 10, 2016 6:15:15 GMT 1
The seal went in harder than the bearing did in my engine.. You deal looks a bit strange? Or is it just me?
Post by shandyboy on Aug 10, 2016 19:52:34 GMT 1
sorted old metal race was still inside knocked it out and jobs a goodin Dooh
