Post by broughton5 on Jul 1, 2014 21:25:30 GMT 1
just stripped my head bearings due to a advisory on being slightly notchy on last mot, is it possible that dirt would be causing this problem has have cleaned them and cant see any damage on bearings or the cones, will be putting them back in after a few other jobs are done whats your thoughts.
Post by raider18 on Jul 1, 2014 21:32:20 GMT 1
as your this far just change um m8 nout worse than doing a job twice
Post by iang1 on Jul 1, 2014 21:35:25 GMT 1
Change them while you have it stripped. Not expensive then just fit and forget
Post by broughton5 on Jul 1, 2014 21:47:56 GMT 1
hear what ur saying but all looks good , suppose i can pop the yoke back in and try it before putting everything else back together.
Post by midlifecrisisrd on Jul 2, 2014 11:06:35 GMT 1
Easy to check with only yokes fitted.
Over tight bearings will feel notchy
Post by yamark on Jul 2, 2014 13:11:37 GMT 1
Post by broughton5 on Jul 2, 2014 17:33:17 GMT 1
cheers lads had guy across road have a look he said should be fine , and has said just fit yokes and see, will be doing shortly when yokes painted.
