Post by martyngsxr1 on Jun 27, 2014 19:41:04 GMT 1
In 2 minds about using a Athena top end gasket set is the head gasket going to leak as soon as I run the bike like other aftermarket gaskets
Post by bare on Jun 27, 2014 20:29:16 GMT 1
For What Bike? IF for a valvie and it's of 3 metal leaves construction, there is little if any difference to an OEM one. No experiences with the one piece Aftermarket LC ones though
Post by ianr4863 on Jun 27, 2014 20:52:13 GMT 1
Im using one on my 4LO at the moment . Not had any problems at all .
Post by martyngsxr1 on Jun 27, 2014 20:54:14 GMT 1
It's on a ypvs don't know if its three leaf as I haven't bought it yet
Post by steven on Jun 28, 2014 11:23:45 GMT 1
Mornin, I have Athena Base gaskets and head gasket on my 4L0, no probs so far. I had to trim the base gaskets as they were overlapping, I found this out when I checked my squish band. Iv had various LC,s over the years, but never checked the squish band on any of them until I rebuilt my current engine. If you are in any way concerned or bothered about checking your squish band, the choice of OEM or pattern head gasket plays a big part, as a genuine head gasket is 2.0 mm thick and an Athena one is 1.2 mm thick, Im not sure how thick other pattern ones are? I read that most mass produced 2 strokes leave the factory with the squish band set rather wide, due the problems encountered acheiving tollerances on mass produced parts, and again from what I read, LC,s were no different. Therefore, a standard LC engine, with an Athena head gasket will have a squish band closer to what it should be than the same engine fitted with a genuine Yamaha head gasket, so ....on a standard LC at least....the ones with Athena head gaskets are the fastest ! Checking the squish band is very easy, and I wont be building any more without checking the squish band. steven.
Post by martyngsxr1 on Jun 28, 2014 13:50:34 GMT 1
Well I bit the bullet this morning and went to fowlers and bought a oem head gasket
