Post by Yogi on Jun 25, 2014 18:05:47 GMT 1
Hi Gang I thought I'd share this with you all as I've seen loads of posts about BLEEDING BRAKES To get an mot on my hybrid.It took 3 days to bleed the back brake! Took it for its first ride and it came loose and gobbed all the fluid out,long story short,the brake line was too well clamped and not enough room for movement! Sorted that and it wouldn't bleed again ,,ended up with paint lifting,trays full of fluid,rebuilt the caliper,replaced the master cylinder twice and still no joy So I bought this off eBay after looking on YouTube BBCode (message boards & forums) Two minutes later and with no mess at all the brake is perfect best £16.49 I've ever spent And to think how much I've spent on parts to make it look pretty but serve no other purpose!!!!
Post by daveadams21 on Jun 25, 2014 19:53:09 GMT 1
I've had a nightmare too with my brakes and I've got the same vacuum kit in my watch list on ebay. I get paid on Friday so it's going to be ordered today. Your post convinced me this is the way. I have spent days trying to get any brake pressure with very little joy and I've wrecked some paintwork too...
So thanks and fingers crossed.
Post by Yogi on Jun 25, 2014 20:04:35 GMT 1
I've had a nightmare too with my brakes and I've got the same vacuum kit in my watch list on ebay. I get paid on Friday so it's going to be ordered today. Your post convinced me this is the way. I have spent days trying to get any brake pressure with very little joy and I've wrecked some paintwork too... So thanks and fingers crossed. You won't regret it Dave,small tip,put a little Ptfe tape around the bleed nipple first and don't open it too much. Cheers Matt
Post by 4l04ever on Jun 25, 2014 22:17:13 GMT 1
Be careful with those kits, as if you pull the hose off the pump, it will rip the pump apart. Once it has come apart it won't stay together as the plastic body is too weak. Just leave the hose on. Don't ask how I know this! :-)
I ended up getting another metal bodied one. (Sealey VS401)
Post by andrew on Aug 29, 2014 17:03:42 GMT 1
So Glad for this thread,,, took my bike round the block for its first shake down on the road, oh my god are those front brakes crap!!!!!!!!!!!! and that's after new pads and an exchange master cylinder.. im absolutlely convinced that I lost the fine art of bleeding (well brakes anyway!!!) Of to eBay with the description now
Post by jackjabba on Aug 29, 2014 17:15:13 GMT 1
I have a kit like that and always use it, does a great job.
Post by she169y on Aug 29, 2014 17:46:35 GMT 1
Heading for e-bay right now. Got to be worth a punt. Thanks
Post by she169y on Aug 29, 2014 17:46:50 GMT 1
Post by raven13 on Aug 30, 2014 0:19:13 GMT 1
all I ever do is reverse bleed using an irrigation sringe on the bleed nipple and slowly pump fluid backwards through the system. never failed me yet
artie
Post by artie on Aug 30, 2014 15:59:11 GMT 1
Post by farmboy on Aug 31, 2014 18:28:48 GMT 1
I am with Raven and Artie , this worked perfect on my 4lO . I did pose for the picture , before you say the tubes full of air locks . I bled up both sides with a single fill.
Post by marsbar350 on Aug 31, 2014 18:42:50 GMT 1
thats what i did artie then went to the local hardware shop and bought same syringe for 45p
artie
Post by artie on Aug 31, 2014 19:19:32 GMT 1
thats what i did artie then went to the local hardware shop and bought same syringe for 45p Dammit as a tight careful Yorkshireman that hurts Andy
Post by jobby on Sept 3, 2014 21:05:26 GMT 1
thx for the post just ordered one as got some nice four pots to blled and i know they can be a pig
Post by muddyfox on Sept 21, 2014 22:37:58 GMT 1
my trick is to bleed the brakes above the master, i just rotate the caliper, prepare for bubbles, works everytime!
scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Sept 22, 2014 23:56:09 GMT 1
Just done mine as replaced the hoses. What a difference to braking now, no pressure needed on lever.
Post by mannanan on Sept 23, 2014 14:20:56 GMT 1
Sorry to be a bit dense but have I got this right for the method with the syringe. You connect up an empty syringe and draw fluid through the system and caliper by pulling/drawing on the syringe and topping up the reservoir as you go? Thanks.
Post by muddyfox on Sept 23, 2014 14:29:23 GMT 1
no mate they are saying reverse bleed as in pump the fluid from calliper to master
heres the quote
all I ever do is reverse bleed using an irrigation syringe on the bleed nipple and slowly pump fluid backwards through the system. never failed me yet
regards
Post by mannanan on Sept 23, 2014 14:49:02 GMT 1
Right! So the syringe is filled with fluid that is pumped backwards through the system to push any air back up to vent into the reservoir? I hope I have it right now. Thanks again.
artie
Post by artie on Sept 23, 2014 20:51:50 GMT 1
Sorry to be a bit dense but have I got this right for the method with the syringe. You connect up an empty syringe and draw fluid through the system and caliper by pulling/drawing on the syringe and topping up the reservoir as you go? Thanks. Actually thats how it worked for me,like a vacuum pump just drawing the fluid through.
Post by powellm976 on Oct 5, 2014 13:29:38 GMT 1
I use the syringe to pull fluid through, also like the pt fe tape on the billed nipples, best trick though is crack the master cylinder banjo bolt with pressure on the lever, a tiny air bubble there is a bitch to remove any other way, make sure you have a rag in the right place to catch the fluid though
Post by yamfan on Oct 6, 2014 22:43:52 GMT 1
I've got one of those vac pump kits, it's brilliant at shifting awkward trapped air.
