Post by stusco on Jun 24, 2014 14:58:11 GMT 1
any ideas why my locating pin does not fit in the recess should i cut it or is somthing wrong?
Post by raider18 on Jun 24, 2014 15:56:01 GMT 1
is that the right way round ? looking down on the motor the cogs should be on the right
Post by stusco on Jun 24, 2014 16:12:56 GMT 1
They are on the right I just took the photo from the front
Post by raider18 on Jun 24, 2014 17:08:35 GMT 1
if you took photo from the front they sould be on the left
Post by stusco on Jun 24, 2014 17:32:29 GMT 1
From the front of the engine(the free end) the cogs are on the left
Post by dusty350 on Jun 24, 2014 17:50:30 GMT 1
Hi, Have you tried to gently tap the pin home a bit more ?
Dusty
Post by muttsnuts on Jun 24, 2014 18:00:32 GMT 1
some of the newer bearings have longer pins these days, you have 4 choices if they are
1. Trim the pin with a dremel or file - but make sure you keep the filings away from the crank etc 2. make the locating hole slightly larger in the crank casing 3. Try tapping the pin further into the bearing 4. Hit the pin with a brass drift to make it locate into the crank casing
HTH
Post by steeley on Jun 24, 2014 18:05:15 GMT 1
hi ,make the recess in the casing for the pin a little bigger for the pin.it may be a bearing from a Suzuki.i have seen a crank with all the pins squashed flat in the casing.
Post by stusco on Jun 24, 2014 18:06:31 GMT 1
Thanks for the answers the pin is fully home so I think I'll trim it,but that means this isn't the crank out of this engine ,never mind it's in good nick
Post by Tone on Jun 25, 2014 6:16:30 GMT 1
Do you know if the crank has been rebuilt? I had the same thing when I got my crank back from Grampians a few years ago. Seem to remember they said that they drill their own bearings for the locating pin when I spoke to them. I carefully filed the end of the pin so it sat in the cases making sure I covered the bearings to stop any filings getting in the bearings.
Tone
stasky
Post by stasky on Jun 28, 2014 10:15:51 GMT 1
yes Grampians used to give you a longer pin on that side, which I personally prefer, rather than the silly little nipple yamaha use,ive seen many spin round and wreck cases
Post by stusco on Jun 28, 2014 14:27:15 GMT 1
I bought the engine stripped the crank looks really good but it has been used as the bearings have marks where theyve been fitted
Post by stusco on Jun 28, 2014 14:28:20 GMT 1
Oh I made the pin recess bigger so alls good now
Post by steeley on Jun 28, 2014 14:40:40 GMT 1
that's the way to do it.no problems next time round.
