PV motor
Jun 7, 2014 13:03:46 GMT 1
via mobile
Post by kostas on Jun 7, 2014 13:03:46 GMT 1
When I turn the ignition on the PV motor does one complete turn stops for a couple of seconds and does one more in the same direction. Have not fitted the cables to the power valves yet.
This can be normal??
Any ideas?
Kostas
Post by rich on Jun 7, 2014 16:44:03 GMT 1
Doesn't sound normal. It should turn part way in one direction and then back the other way.
Post by yamark on Jun 7, 2014 17:17:11 GMT 1
+1
PV motor
Jun 7, 2014 18:07:41 GMT 1
via mobile
Post by kostas on Jun 7, 2014 18:07:41 GMT 1
+1 for me also, now to find what is wrong with it..
Post by Shytalk on Jun 7, 2014 19:53:34 GMT 1
Most likely the servo motor is goosed as when you turn the ignition on all it will get is 12V supply from the battery and it should complete it's cycle correctly.
Post by rich on Jun 7, 2014 22:14:07 GMT 1
It could be the servo or the controller module.
