Post by kostas on May 18, 2014 17:11:08 GMT 1
Hi guys, As above I have a set of 31k carbs and as you can see at the picture the let one is missing a brass plug at the few side. Should this be open or not?? Thanks Kostas
Post by Tone on May 18, 2014 18:32:28 GMT 1
Don't worry, this is how they are. If you try blowing down the hole you will find it is blocked off. The spare set of carbs and the ones on my LC2 are exactly the same.
Tone
Post by kostas on May 18, 2014 18:48:53 GMT 1
Not blocked off Tone. Gave it a blow and air goes thru!!
Kostas
Post by Tone on May 18, 2014 20:52:33 GMT 1
Just checked the spare set of carbs and pushed a small piece of heat shrink down the hole and and tried blowing and it is definitely blocked . Where is the air coming out of yours ?
