Post by stusco on May 13, 2014 17:16:25 GMT 1
Can anyone tell me which model of zxr 400 forks and yokes are the easiest to fit to a 350 lc
Post by Kryten on May 13, 2014 17:57:03 GMT 1
Currently having my ZXR400L yokes altered by Nigel at NK racing to fit my F2,there's no easy way with them as you need a stem swop due to there being no bearing size that will fit over the stem and fit inside the headstock.So i should say it would be a similar process with your LC.
Post by stusco on May 13, 2014 18:48:06 GMT 1
Cheers I have my eye on a set of l yokes and forks, how much did the process cost if you don't mind
Post by Kryten on May 13, 2014 19:53:53 GMT 1
Machining the top yoke so the orignal ignition barrel fits and stem swop, or he did say he may make a new stem plus altering the lock stops would be in the region of £80-£100. Don't quote me on that though as im having a adaptor kit for an rgv swingarm which bumped up the price a bit.I'll give you a proper price when i get the bill.
Post by stusco on May 13, 2014 21:32:40 GMT 1
Thanks
