Post by pistanbroke on May 4, 2014 19:22:22 GMT 1
Checked the oil today as the expansion bottle for the rad was low and YEP!! water in the gear oil , gutted!!! Im assuming the water pump oil seal is fooked ? Anyway been a few years since ive done this job so advice greatly appreciated, right so I need from the back off my heed new seal!! change the water pump bearing while im at it??? yes ? no? gaskets for the relevant casings !! Anything else I should do while im in there ?? i'll be phonin Norbo for the bits I need , anything else you guys can add be most welcome cheers guys
Post by Deleted on May 4, 2014 21:04:34 GMT 1
Mine went two years ago on My way to norbos for the BBQ Managed to limp her there I changed the seal the bearing and since there was scoring on the impeller, I put a high gain impeller on it as well
Post by Yogi on May 4, 2014 21:09:03 GMT 1
You might as well change the rubber o ring on the bottom ally hose that goes through the casing,check clutch and gear adjustment too
Post by pistanbroke on May 5, 2014 19:52:57 GMT 1
Thanks a lot lads
Post by marsbar350 on May 5, 2014 20:00:06 GMT 1
a bit of wet and dry to take the marks out saves ya £40 good to go who changed it mick mr silver
Post by Deleted on May 5, 2014 23:24:50 GMT 1
Yup he did.
