Post by shaunthe2nd on Apr 15, 2014 7:30:18 GMT 1
What clips onto this lug on the 250LC?
Post by steeley on Apr 15, 2014 8:08:11 GMT 1
I think that is where the indicator self cancelling unit goes.its an oblong rubber box with a loop on it and wires out the one end .hope this helps you.
Post by shaunthe2nd on Apr 15, 2014 8:52:18 GMT 1
Thanks for that. That's why I didn't remember removing anything from it, as this is a Swedish import bike which I don't believe had the self cancelling indicators.
I have seen these units on ebay, if I buy one does it simply plug into somewhere on the loom and work like magic, or is it a bit more complicated than that?
For some reason the 250LC parts catalogue I have doesn't show a self cancelling unit.
Post by 4l04ever on Apr 15, 2014 11:02:22 GMT 1
You have to fit the self cancelling unit and change one wire on the flasher unit. If you look at the wiring diagram you will see it. There is always a spare wire left over at the flasher unit, and that is swapped with a different wire to include or exclude the self cancelling unit.
Post by farmboy on Apr 15, 2014 19:52:11 GMT 1
Hi Shaun , I know you are way past this stage by now.
But it reminded me off something. You want to make sure you clean some of the coating off just around the bolts where the coil sits , if you look at the coil the metal core comes out each end and this has to have a very good earth contact on the frame. it may get enough contact just through the bolts . But always good to cover all bases , just put some wd or light grease around the area after you have fitted it.
Post by shaunthe2nd on Apr 16, 2014 7:31:56 GMT 1
Good point. Thanks
