Post by nuttytart350 on Oct 30, 2005 22:17:58 GMT 1
hi everyone or anyone new bod on the block - just bought a 350R ypvs today to try and recapture my youth - last 2stroke was a 400E tuned and went like stink (20 years ago) anyway this is a bit of a let down - on the M11 going home wouldn't hold top gear at 70 - flat as a very flat thing - wot do you advise (don't be rude) to put the pep back - pipes/tune/carbs/wotever.
Post by Norbo on Oct 30, 2005 22:47:56 GMT 1
Hi and welcome to our little family. The 350R is the most restrictive of all the valves. But dont worry its still Plenty of poke. You need to down sprocket 1 tooth on the front to make it rev a little more If you get some reed spacers and a boost bottle and Hi-teck reeds this will make it pick up loads faster and rev more and give you about 6 BHP more in the midrange but more then that they make the bike revs pic up faster and with a smaller foont sprocket you will find it a lot better. The only other things you can do it put a set of pipes on it and put a lightened flywheel on . with theys as well you will fined it a very fast and fun bike but the R will need theys to make it a good fast bike.
Post by vinze187 on Oct 30, 2005 23:02:10 GMT 1
Hello nuttytart welcome aboard!!
Post by vinze187 on Oct 30, 2005 23:06:14 GMT 1
oh jeeese two nutters on the board!! I doubt she can you as nuts as you nuts!
gazmo
The missus said Ive out grown the bike I dont see what the problem is!
Post by gazmo on Oct 30, 2005 23:15:33 GMT 1
Hi from one newbe to another Im envious at least you can ride yours mine is still in a pile on the garage floor minus an engine at the mo.
Post by nuttytart350 on Oct 30, 2005 23:18:33 GMT 1
Thanks 4 the advice Norbo - where do i get hold of the parts - and wot pipes - i see stan the man makes his own (first web site i was on - then this un - very impressed by your knowledge of elsie ) has anyone tried stan's pipes - or maybe you could do me a set - i've been reading your older posts and threads
Post by nuttytart350 on Oct 30, 2005 23:29:40 GMT 1
Hi gazmo - don't be too envious - mine will be in bits soon enough - i want it to go like it should - but also stop !!!!! - its a bit lacking at the mo - perhaps the later calipers - and legs to think of it - might fit (R1 or R6) any ideas norbo
Post by Norbo on Oct 30, 2005 23:39:48 GMT 1
Hi there I have just about everything The spacers are £20 the extra long plated allon bolts are £3 Boost bottles are £30 polished to see your face in The Racing reeds are £24 Lightend flywheels are £60 I have some Formula 2 race pipes at the moment brand new they are £250 with alloy cans. and are the best you will get any where. I have the jets you will need to up jet as well they are £3 for the 2 i can tell you what jets you will need . Its not cheep to get power but i have to say that if you did do the lot you would be keeping up with 600's in a race round the twisteys . If your not sure about anything feel free to call me for a chat a lot do and i dont mined so long as i can help with bits or just advice im allways at the end of a phone or on here ;D
Post by nuttytart350 on Oct 30, 2005 23:45:24 GMT 1
Hi Typan - not related except in spirit - but then again aren't we all - must be something to do with the smell and the ringadingding
Post by Norbo on Oct 31, 2005 0:02:53 GMT 1
I have R1 calipers aswell and disks that will bolt on to.
Post by nuttytart350 on Oct 31, 2005 0:06:40 GMT 1
I'll be ringing you monday evening Norbo for a chat about the parts - it's got to be done !!!
Post by daz on Oct 31, 2005 12:52:29 GMT 1
Hi i have a 93 350r with a set of F2 carbs micron pipes and S&B air fillter on it.It done 125mph over the mountain at IOM.
Post by daz on Oct 31, 2005 13:02:00 GMT 1
If looked after they are very reliable bikes .I have had mine from new in 93 it has 34K engine never never been apart
Post by nuttytart350 on Oct 31, 2005 14:40:54 GMT 1
Hi daz thanks 4 the encouragement - the bike has 21K on the clock and sounds ok on start up from cold so i think it might just need some TLC a good service then a good thrashing (or maybe i do) but it wont hurt to put a few performance parts on - here what do you think about the brakes - mine are poor - more TLC needed
Post by daz on Oct 31, 2005 15:04:25 GMT 1
Hi nuttytart350 fit goodridge hoses and ebc green pads and give calipers a good clean will make a brakes a lot better.
Post by vinze187 on Oct 31, 2005 19:13:34 GMT 1
will R1 callipers fit RGV wheels? please say yes! lol
gazmo
Post by gazmo on Oct 31, 2005 23:31:19 GMT 1
;D Ive just picked up some fartblood calipers Im going to see if they fit if not Ill get some adapter plates made up .Im no stunt master but it looks as though I might be practising stoppies when I get it on the road ;D ;D ;D ;D
Post by Norbo on Nov 1, 2005 20:07:52 GMT 1
I think you will need to make hangers for the calipers . Its not a hard job i have made a few in my time. It takes a long time to get them to looking nice, but it can be done and only costs about £5 in alloy
Post by nuttytart350 on Nov 7, 2005 19:25:08 GMT 1
hiya nutters - not touched it this weekend - weather crap - i have to work outdoors on me bikes - also only got carbs so far tzr250 28mm jobbies - stripped em - cleaned em - put back together - (only a few bits left over) - i'm waiting for norbo to post all me other bits - pipes.boost bots.lightened flywheel.
Post by nuttytart350 on Nov 7, 2005 19:57:47 GMT 1
norbo says will breath better with em - 26mm std - so 2mm bigger - not too big for bottom end power - plus all the other bits - oh and the reeds - should fly
Post by Norbo on Nov 7, 2005 23:18:48 GMT 1
[/quote] Glad its all coming together Will the TZR carbs make much diference? [/quote] She has the R model from brazil and the carbs restrict it so with a set of pipes on a set of free flowing TZR28mm carbs will help a lot . I think they are one of the best carbs you can put on a LC or Valve with the Kwak KR1 carbs.
Post by Norbo on Nov 9, 2005 12:03:26 GMT 1
Put a pic up i think they may be RZ250 pips
Post by mellow on Jan 4, 2006 22:07:32 GMT 1
am i missin summin here
Post by nuttytart350 on Jan 4, 2006 23:41:19 GMT 1
whats the latest on your R model ? ER.....not a lot... ......the front and rear end fell through.. ..so i've been sortin the TDR cos it didn't require the same sort of work.....I need one good 2 stroke runnin for me jollies.... ....then I won't rush the hybrid.....
Post by vinze187 on Jan 6, 2006 21:51:30 GMT 1
ooo a blast from the past there nutters! lol
Post by mellow on Jan 6, 2006 21:52:44 GMT 1
allo vinze where u been
Post by vinze187 on Jan 6, 2006 21:54:46 GMT 1
man i been working 12 hr days and then the misses started with the you send more time on that computer than talking to me lol so i had to please her for a few days to keep the peace! lol
Post by mellow on Jan 6, 2006 21:55:34 GMT 1
ha nice 2 see u back u aint locked her in the shed av ya
Post by vinze187 on Jan 6, 2006 23:06:20 GMT 1
no mate she could do some serious damage, me project in there and a whole bunch of power tools! lol Either that or itll be like the A team and she'll make some deadly weapons in there lol
Post by mellow on Jan 6, 2006 23:07:47 GMT 1
yeah i know...........lets make a helicopter with loadsa firepower out of just this matchbox ;D
