Post by kostas on Apr 7, 2014 20:21:41 GMT 1
I'm about to paint my barrels and I don't like using rattle can hi temp paint.
Was thinking of using 2 pac epoxy primer and 2 pac silver paint. Will this hold up? There should not be to match heat with a water cooled engine... Has anyone tried this before?
Kostas
Post by steeley on Apr 7, 2014 20:35:07 GMT 1
yes 2 pack paint will be ok.years ago had my 350 lc engine painted with 2k paint ici make.looked good for years.know what you mean about rattle cans the stuff is not very durable,chips,scratches oh and todays petrol marks it as well.
Post by screwdriver on Apr 10, 2014 19:36:58 GMT 1
For a quick result, mask off with that alloy ducting tape (not duct tape or gaffer!) Garbage matte or rough mask with a few sheets of paper Barbecue paint dries in minutes and goes matt. Polish it up a bit with a dry rag. Job jobbed. You can always go back and strip recoat it properly but most of these e machines will get a flashover like this once in their lives and when it's been den once, you either strip it fully and do it properly or, if you can't beat 'em... S.
Post by kostas on Apr 11, 2014 16:09:27 GMT 1
I was worried more about the temp the normal 2 pac paint can handle. As said it should be fine so I'm going to paint those property.
Thanks
Kostas
Post by shane250 on Apr 11, 2014 18:31:59 GMT 1
im not sure why you wouldnt use a rattle can Plasticote BBQ paint is simple and very effective.No primer no messing and a perfect finish.
Post by kostas on Apr 11, 2014 21:00:02 GMT 1
im not sure why you wouldnt use a rattle can Plasticote BBQ paint is simple and very effective.No primer no messing and a perfect finish. Will it hold against petrol? Kostas
Brass
Post by Brass on Apr 11, 2014 21:45:03 GMT 1
Duplicolor engine paint, high temp, resists petrol, no primer. Put thin coats on. Goes a kind of satin finish. I have done a few bikes with it now, no problems.
Post by shane250 on Apr 12, 2014 0:28:02 GMT 1
Provided you stick them in the oven for curing yes holds up great against fuel.I've had quite a bit on my side casings from messing with jetting and not a blemish.
Post by Denzil on Apr 12, 2014 10:35:08 GMT 1
BBQ paint is very good for this as long as you stick it in the oven and cure it. If done properly it will resist petrol splashes and knocks. Does look good as it will polish up as well.
