Post by looey on Apr 4, 2014 10:40:40 GMT 1
Trying to sort an intake leak on my Hybrid . Can anyone tell me what gaskets would have been supplied with the Vforce3 reeds and where they should be fitted, i.e. both sides of the reed assembly, or just between the reed assembly and the barrel inlets ?. Also, fitting KR1s PWK28's with the Vforce3 reeds to the YPVS 350, do they use the standard YPVS carb inlet rubbers ?. Thanks
Post by looey on Apr 4, 2014 11:18:13 GMT 1
Cheers for that, sounds like mine is the same problem !.
The bike came with them already fitted and they look like home-made gaskets which aren't quite the same each side !.
It's not running quite right and when I've ridden for a while, I can see a mixture patch seeping from the top of the joint between the inlet rubbers and the reed block !.
So they are standard YPVS 350 inlet rubber that will take the PWK28's and have the inner ears cut off to mate with the Vforce reeds correctly ?.
Is that right ?.
Post by Deleted on Apr 4, 2014 11:36:02 GMT 1
On my 4lo I have some 63mm tractor radiator hose from air box to the carb, but was told standard rubbers would fit if warmed up then stretched over a beer bottle. Know yours is power valve but hope it helps
Post by looey on Apr 4, 2014 11:42:23 GMT 1
Yes thanks guys, I'll get on it now. I'll get some new inlet rubbers as well, as mine are starting to show external sights of cracking (only very very slight on the surface though) Cheers again
Post by looey on Apr 4, 2014 12:34:19 GMT 1
Does anyone know a Vforce stockist I could get new gaskets from ?.
Post by looey on Apr 4, 2014 14:17:41 GMT 1
Yeah ta for the link.
That will be ok for the Carb rubber to reed block joint but will it go over the larger vforce reeds ?.
I've got an old standard gasket here and it doesn't go over the reed petal side ?
Post by looey on Apr 4, 2014 15:48:22 GMT 1
Right all back together with gaskets both sides. Used the 2 existing gaskets and made 2 new ones. Thanks for the input
