Post by shaunthe2nd on Mar 16, 2014 9:01:43 GMT 1
I had trouble sealing end of the pipes when decoking with caustic soda recently. Saw some tips on here to use squash ball or various vegetables. I used clingfilm and tape but still had some leakage. I searched the cupboard under the sink and found a number of plastic spray can tops perfectly fit the end of a 350/250 LC end pipe. Held them in place with some tape and seems to do the job. I also found that if you bolt the 2 pipes together whilst decoking they are a lot more stable. So this is how i'm decoking a set at the moment.....
Post by Yogi on Mar 16, 2014 12:19:29 GMT 1
You should of used matching lids
Post by steve h on Mar 16, 2014 12:32:30 GMT 1
Yes........and satin tape.
Post by marsbar350 on Mar 16, 2014 19:04:12 GMT 1
looks like you have 1 250 and 1 350 pipe
Post by steeley on Mar 16, 2014 19:14:23 GMT 1
ah some of these lids have a hole in them.
Post by shaunthe2nd on Mar 16, 2014 21:23:43 GMT 1
looks like you have 1 250 and 1 350 pipe Is this a jolly jape about the red/blue or have you seen something I haven't? The pipes are correctly referenced as far as I can see, and have the '0'stamped on the hanger, and I bought them as a pair. Shaun
Post by marsbar350 on Mar 16, 2014 21:34:52 GMT 1
just the caps used bleu dot 350 red for 250
Post by shaunthe2nd on Mar 16, 2014 22:08:01 GMT 1
Was a bit worried for a mo. Funnily enough these both had traces of an orange dot on the hanger when I rubbed them down which i believe is a 350 marker.
Next time I go shopping all my sprays will have blue caps!
Post by marsbar350 on Mar 16, 2014 22:10:52 GMT 1
yanking your chain shaun keeps you on those toes
Post by shaunthe2nd on Mar 16, 2014 22:29:54 GMT 1
Post by steve h on Mar 16, 2014 22:43:40 GMT 1
On the subject of causticing pipes. Has anyone used drain cleaner? Its bloody strong and dangerous stuff. If it dissolves fat and hair and lumps of shite maybe it might be of use in an exhaust?
Post by marsbar350 on Mar 16, 2014 22:52:15 GMT 1
good for "losing" murder victims
Post by steve h on Mar 16, 2014 22:56:22 GMT 1
Post by shaunthe2nd on Mar 16, 2014 23:08:39 GMT 1
On the subject of causticing pipes. Has anyone used drain cleaner? Its bloody strong and dangerous stuff. If it dissolves fat and hair and lumps of shite maybe it might be of use in an exhaust? or a wife?
Post by Yogi on Mar 16, 2014 23:45:05 GMT 1
quote]or a wife? [/quote] Hope your missus don't know your password Shaun
Post by steeley on Mar 17, 2014 13:33:14 GMT 1
would that be killrock, nasty stuff the fumes are enough to take your breath away.dont forget your ppe.
Post by 4l04ever on Mar 18, 2014 12:52:12 GMT 1
just the caps used bleu dot 350 red for 250 I thought Blue dot was the modified 1981 250LC pipe??? :-)
Post by shane250 on Sept 22, 2014 14:36:58 GMT 1
These are 250....
Post by steven on Sept 22, 2014 14:56:00 GMT 1
Hi, The various colour codes are on here.
