Post by tell7437 on Feb 23, 2014 0:19:01 GMT 1
Anyone got any good ideas on the neatest way to recess a 4lo tailight, i hate botch jobs & wondered if anyone had any pics on how they have done it
Post by Deleted on Feb 23, 2014 9:47:20 GMT 1
you have pm....
Post by casperdog on Feb 23, 2014 10:12:37 GMT 1
any chance of posting it on here, was after the same info / ideas myself......thanks
Post by marsbar350 on Feb 23, 2014 10:58:27 GMT 1
trubrits has done a few have a look at his bikes in the rebuild section
Post by robin on Feb 23, 2014 19:25:17 GMT 1
this was they way I found my tail light done, maybe I wouldn't do it this way if it was me, as it seems crass to cut up good plastic, but if you have a spare tatty one maybe useful information.
Post by lcyoungboy on Mar 12, 2016 20:50:44 GMT 1
Wouldn't mind doing this mod myself..anybody have any info? Dave
Post by KevtheRev on Mar 12, 2016 20:57:59 GMT 1
I have a tatty unit like that Dave , if you want one to cut up .
Post by 4l04ever on Mar 12, 2016 22:57:50 GMT 1
Someone used to make a metal kit that was adjustable.
Post by stusco on Mar 12, 2016 23:32:14 GMT 1
Someone on eBay was selling a kit for £165 bit steep for me
Post by JonW on Mar 13, 2016 6:49:50 GMT 1
have a search in here, weve talked about this and there is all the info you need about 3-4 months back.
Post by headcoats on Mar 13, 2016 9:43:04 GMT 1
It's just something you don't need to do
Post by lcyoungboy on Mar 14, 2016 19:26:02 GMT 1
have a search in here, weve talked about this and there is all the info you need about 3-4 months back. Im usually good with the search box but can't find any info at all...
Post by looey on Mar 14, 2016 19:37:16 GMT 1
I've done it few times before.
The easiest way is not to touch where the rear light bolts to the plastic tray. Just unbolt the tray, pull it forward until the rear light is where you want it, then make new holes through the tray to bolt in the new (further forward) position. You can easily do any trimming to the tray (front and sides) as needed.
Post by dave1963 on Mar 14, 2016 20:04:37 GMT 1
I've done it few times before. The easiest way is not to touch where the rear light bolts to the plastic tray. Just unbolt the tray, pull it forward until the rear light is where you want it, then make new holes through the tray to bolt in the new (further forward) position. You can easily do any trimming to the tray (front and sides) as needed. I did the same to mine very easy
Post by JonW on Mar 14, 2016 22:21:03 GMT 1
Post by lcyoungboy on Mar 14, 2016 22:48:36 GMT 1
Thanks lads
Post by threefifty84 on Mar 15, 2016 21:02:02 GMT 1
I did this back in the day. I didn't want the rear mudguard either but didn't want to chop it. All I did was Strip out the tray and mudguard then with fibreglass and mesh made a flat platform and then held the light unit in place with a couple of strips of metal, bent, drilled and bolted to the sub frame. It was cheap,strong and everything could be put back if needed.
Post by oldelsieboy on Mar 15, 2016 21:19:44 GMT 1
Anyone got any good ideas on the neatest way to recess a 4lo tailight, i hate botch jobs & wondered if anyone had any pics on how they have done it This is surplus to requirements. OEB
Post by JonW on Mar 15, 2016 22:26:23 GMT 1
Thats the one I was after, PM sent Nigel.
Post by lcyoungboy on Mar 15, 2016 22:40:40 GMT 1
Any1 else got a spare 1 for sale??
Post by bazzer5115 on Mar 16, 2016 11:19:57 GMT 1
Easy to make your own.make a cardboard pattern,transfer to a piece of alloy,cut ,drill and fold,job done.simple!!!
Post by JonW on Mar 16, 2016 11:38:41 GMT 1
I agrea bazzer, Ive asked Nigel to trace round it and do a bit of measuring, it would be great if he could do that. Its simpler for me to make one than have one sent really :/
Post by robin on Mar 16, 2016 13:40:44 GMT 1
If anyone has a template would they mind sharing, I would like to make one of these myself to loose the cut down plastic try in there at the moment, it looks a bit cack.
Thanks in advance
Robin
Post by oldelsieboy on Mar 16, 2016 13:41:28 GMT 1
I have this morning been in contact with a local engineering firm who are going to give me a price to have a small batch of these brackets made. They will be similar to the photo above but will also include a number plate mounting bracket. Will update later with price.
OEB
Post by dusty350 on Mar 16, 2016 13:52:57 GMT 1
Nice one Nigel I would be interested in one for the 385. Dusty
Post by unrealedd on Mar 16, 2016 14:24:51 GMT 1
Nice one Nigel I would be interested in one for the 385. Dusty For 385 dusty I'm sure you could have two ?
Post by dusty350 on Mar 16, 2016 14:42:26 GMT 1
Post by rigga on Mar 16, 2016 15:49:45 GMT 1
Nice one OEB
Post by robin on Mar 16, 2016 20:32:18 GMT 1
I have this morning been in contact with a local engineering firm who are going to give me a price to have a small batch of these brackets made. They will be similar to the photo above but will also include a number plate mounting bracket. Will update later with price. OEB Yes please mark me down for 1 as well, TIA OEB
Post by redbimota on Mar 16, 2016 22:09:40 GMT 1
I would like one please
