Post by botty on Feb 10, 2014 17:46:09 GMT 1
Just put the bottom end together on a ypvs engine. The sprocket can be moved back and forth to the value of 2 teeth before it engages with anything. Does that seem right??
Post by midlifecrisisrd on Feb 10, 2014 17:54:30 GMT 1
That will be normal as there is play between the pins on one gear and the slots it locates to.
No play would stop the gear engaging
Post by arrow on Feb 10, 2014 20:09:29 GMT 1
That will be normal as there is play between the pins on one gear and the slots it locates to. No play would stop the gear engaging Steve +1
Post by rich on Feb 10, 2014 20:10:21 GMT 1
Dogs
Post by botty on Feb 10, 2014 20:18:36 GMT 1
That will be normal as there is play between the pins on one gear and the slots it locates to. No play would stop the gear engaging Steve +1 Thanks chaps I'm beginning to stress slightly less.
Post by botty on Feb 10, 2014 20:19:27 GMT 1
Dogs? What do you mean Rich.
Post by wawenwong on Feb 10, 2014 21:04:22 GMT 1
I will check mine tomorrow Tony and let you know.... but like the guys say I think its about right
Post by Roofmonster on Feb 10, 2014 21:09:02 GMT 1
Dogs? What do you mean Rich. The pins and slots in the gears are called dog clutches as the gears themselves are always in mesh.
Post by rich on Feb 11, 2014 12:56:18 GMT 1
Dogs? What do you mean Rich. Sorry I should have explained a bit more! Not all of the gears in the box are splined onto the gear shafts. Some gears are 'floating' and drive by engaging with the fixed gears using dogs (pins) and slots. As per Roofmonster and Steve's replies, there is some play to allow the dogs to engage properly. What you are feeling is the play between the dogs and slots. This pic will hopefully show it better (random Google pic, not an RD!):
Post by botty on Feb 11, 2014 21:30:03 GMT 1
Thanks Rich. A picture is worth a thousand words
