Post by shaunthe2nd on Feb 7, 2014 23:34:32 GMT 1
This might be a daft question, but can i replace the temp sender on my 4L0 without draining any fluids?
The manual and parts list I have doesn't even show it.
Thanks in advance. Shaun
Post by 47steve on Feb 8, 2014 8:31:03 GMT 1
As long as the system is not pressurised I can't see it being a problem? You might have fluid running out due to gravity but if you do it quick and top up I think it should be ok? Surely someone will tell me if I a, wrong!
Post by iang1 on Feb 8, 2014 9:32:38 GMT 1
Steve is right, as long as the system is cool you will get a small dribble of coolant but do it quickly it's not a problem.
Post by iang1 on Feb 8, 2014 9:33:03 GMT 1
Post by Delbert on Feb 8, 2014 17:34:18 GMT 1
As above and leave the rad cap on it will slow the flow
Post by stfocus on Feb 8, 2014 19:56:05 GMT 1
Yes u will be ok do it cold u will loose just a little bit as I did mine to day and all was well
Post by budgie on Feb 8, 2014 20:56:20 GMT 1
+1
Post by shaunthe2nd on Feb 9, 2014 13:04:18 GMT 1
Thanks fellas. I've ordered one of those land rover ones that people have mentioned, at a fraction of the cost of the yamaha one. Hopefully will arrive in next few days and looks an easy job to fit if i don't have to drain the fluids, I don't want coolant all over my lounge carpet!
