Post by shaunthe2nd on Jan 27, 2014 13:57:13 GMT 1
How easy is it to remove and replace the rubbers on the footpegs as i want to clean up, paint and generally refurbish them, but the rubber looks like it could be a fighter!
Post by copper99 on Jan 27, 2014 21:43:19 GMT 1
I had more bother putting the new ones back on !
Post by shaunthe2nd on Jan 27, 2014 22:10:10 GMT 1
I had more bother putting the new ones back on ! That's my fear too. any tips? I thinking of sitting them in boiling water first, and spraying wd40 on the footrest before sliding them on. Sounds easy....! Just cut the old ones off, that wasn't too bad a job.
Post by copper99 on Jan 27, 2014 23:30:27 GMT 1
I just gave them a good whack with a rubber mallet in the end Shaun.
Post by tout on Jan 28, 2014 0:10:09 GMT 1
sounds like you already have the solution ! boiling water & a tad of grease does the trick......its down to brute force
If you have a c**k like a handlebar grip then your laughing !
Post by shaunthe2nd on Jan 28, 2014 10:59:53 GMT 1
sounds like you already have the solution ! boiling water & a tad of grease does the trick......its down to brute force If you have a c**k like a handlebar grip then your laughing ! I won't be laughing then!
Post by foxyjohn on Jan 28, 2014 12:25:52 GMT 1
Or spray the insides in WD40 ? + 1
dal68
Post by dal68 on Jan 28, 2014 17:14:05 GMT 1
Just put them in hot water first
Post by shaunthe2nd on Feb 2, 2014 17:49:12 GMT 1
I can't believe how easy the new ones went on. Had my pan of water boiling and wd40 to hand, thought i would offer the rubber up to the footpeg to see how tight it was, and hey presto i managed to slide it on without any trouble without the need for either. After the messing about i had with the handle bar grips i thought these would be a lot harder to replace. Thanks for tips though.
