Post by petehodges on Jan 4, 2014 23:24:36 GMT 1
Ok I spray painted my top & btm yolks a year ago a they're now looking crap If I strip them off is it ok too powder coat them also both my switches need painting as well Also does powered coating remove chrome as I have a spare yolk in shed ? Cheers pete
Post by dusty350 on Jan 4, 2014 23:38:26 GMT 1
Hi, You can powdercoat yokes. Just mask up all the areas you don't want the powder to go. I've had some done before; The blasting process that prepares your part may remove chrome. Best ask the firm you intend using. Dusty
Post by petehodges on Jan 4, 2014 23:43:12 GMT 1
Can I reuse bearings mate or must I replace as they're not very old Cheers dusty
Post by scott on Jan 4, 2014 23:53:01 GMT 1
Can I reuse bearings mate or must I replace as they're not very old Cheers dusty the bearings must be removed for powder coating anyway m8
Post by dusty350 on Jan 5, 2014 0:03:09 GMT 1
Hi As Scott says, bearings and anything not heat proof should be removed. The blasting process will trash them even if the heat didn't. I presume you have taper bearings fitted ? If so, if you can carefully remove them without damage, they should be ok to re-use.
Dusty
Post by petehodges on Jan 5, 2014 0:16:24 GMT 1
Yep I like to save them if poss . Next up what would do with switch gear powder coat or paint ? Just want too give them it all in one hit thanks
Post by scott on Jan 5, 2014 0:22:34 GMT 1
Yep I like to save them if poss . Next up what would do with switch gear powder coat or paint ? Just want too give them it all in one hit thanks powder coat is better, paint is easier. you need to completely strip and blank off all threads for powder coat then remember how to put em back together
Post by Shytalk on Jan 5, 2014 0:25:11 GMT 1
Yep I like to save them if poss . Next up what would do with switch gear powder coat or paint ? Just want too give them it all in one hit thanks Powder coat them Pete, just strip them down, take some pictures as you do it so you know how they go back together though.
Post by petehodges on Jan 5, 2014 0:41:00 GMT 1
Will do cheers lads I'll make a start in morning
