Post by kostas on Jan 3, 2014 22:11:33 GMT 1
The top engine case has some nasty chain damage, see picture, I have a good top case to cut the missing piece off but the question is how do I repair this one. Do I weld it on or use JB weld? Afraid welding heat may distort the case.. I have heard of people doing this repair but never seen pictures or a repair. Cheers Kostas
m1ke
Post by m1ke on Jan 3, 2014 22:18:12 GMT 1
Welding is definitely the better option. Done by a professional they will not distort the cases.
Post by marsbar350 on Jan 3, 2014 22:27:41 GMT 1
hi kostas have you got a guy locally that can alloy weld when you cut the piece you need off the donor case cuta few thin strips as well.these can be used to weld the parts together
Post by oldelsieboy on Jan 3, 2014 22:45:39 GMT 1
Get it professionally repaired. This was mine before and after OEB
Post by steeley on Jan 4, 2014 6:23:40 GMT 1
yes get the damage welded. oeb that's a great job you had done there on your case.
Post by smokin074 on Jan 4, 2014 8:03:27 GMT 1
Yes get welding done , olde top job
Post by kostas on Jan 4, 2014 17:55:28 GMT 1
Get it professionally repaired. This was mine before and after OEB Great looking repair there OEB, my case is a lot worse and complicated than that I hope a good welder can get this done. Thanks Kostas
Post by kostas on Jan 4, 2014 18:00:53 GMT 1
hi kostas have you got a guy locally that can alloy weld when you cut the piece you need off the donor case cuta few thin strips as well.these can be used to weld the parts together Good idea to get the same material for welding, but what kind of weld should that be, TIG, MIG, oxy-acetylene? This might be a stupid question.. Kostas
Post by marsbar350 on Jan 4, 2014 18:05:43 GMT 1
tig welding spoke to me welder and he said its not a problem
Post by kostas on Jan 4, 2014 18:08:20 GMT 1
Thanks Marsbar
Kostas
Post by steeley on Jan 4, 2014 18:16:07 GMT 1
Kostas ,that would be tig welding.i have in the past mig welded a replacement side engine case spigot on my 350lc engine.it don't look pretty but its on the engine and does the job.years ago I saw a chap I used to work with make some repair panels for a landrover discovery out of ali and he welded them on with an oxy set.
Post by kostas on Jan 4, 2014 18:48:02 GMT 1
I also think TIG is the right way. In reality this part does nothing but to keep the engine clean from chain crap.
So what I need is a clean solid weld that can be grounded down to make invisible. The case is getting painted so I won't go nuts about it.
If is wasn't a maching numbers bike maybe I would leave as is.
Kostas
