Post by petehodges on Jan 1, 2014 21:35:41 GMT 1
Spent a few hours in shed tonight and almost there with clocks I,ve used lc2 loom fitted in lc clocks Just one problem really the high beam light indicator on clocks stays on the lights are fine just clock light stays on
Do I have to the clocks advice please lads ?
Post by soccersmyth on Jan 1, 2014 22:00:53 GMT 1
Did you have the LC2 clocks on the bike and all connected up to the LC2 loom ?
Post by petehodges on Jan 1, 2014 22:09:24 GMT 1
Did you have the LC2 clocks on the bike and all connected up to the LC2 loom ? Hi John all connected but not fixed right in a going to change the clock face But have run all wires and connections
Post by muttsnuts on Jan 1, 2014 22:25:43 GMT 1
you've gopt one of the permanent lives mixed up with the switch live, recheck your wiring, those brown wires are a bitch as there are so many of them, some being permanent and some being switched, use a multimeter to work out which is the high beam circuit and check what your high beam indicator wire is connected to - think it should be yellow if memory serves me right
Post by petehodges on Jan 1, 2014 22:49:48 GMT 1
you've gopt one of the permanent lives mixed up with the switch live, recheck your wiring, those brown wires are a bitch as there are so many of them, some being permanent and some being switched, use a multimeter to work out which is the high beam circuit and check what your high beam indicator wire is connected to - think it should be yellow if memory serves me right Don't think I have as pluged them straight intoo loom not done any cutting just fitted them into lc clocks ?
Post by soccersmyth on Jan 1, 2014 23:05:57 GMT 1
you've gopt one of the permanent lives mixed up with the switch live, recheck your wiring, those brown wires are a bitch as there are so many of them, some being permanent and some being switched, use a multimeter to work out which is the high beam circuit and check what your high beam indicator wire is connected to - think it should be yellow if memory serves me right Don't think I have as pluged them straight intoo loom not done any cutting just fitted them into lc clocks ? Right, lets clear something up here with a yes or no answer Pete. When You had the LC2 clocks/clock loom connected up to the LC2 main loom thats fitted to your LC, everything lit up and worked fine ?
Post by petehodges on Jan 1, 2014 23:13:35 GMT 1
Don't think I have as pluged them straight intoo loom not done any cutting just fitted them into lc clocks ? Right, lets clear something up here with a yes or no answer Pete. When You had the LC2 clocks/clock loom connected up to the LC2 main loom thats fitted to your LC, everything lit up and worked fine ? Yes mate all lit up only thing I should say is didn't use my old kidney clock loom Just brought one of eBay that exally the same all uncut and plugged straight in
Post by soccersmyth on Jan 1, 2014 23:19:58 GMT 1
Possibly the loom you bought is the problem.
Right, so the original clock loom is still in the kidney clocks.
Plug the kidney clocks into the LC2 loom and check that every bulb lights up what it should.
Let me know how you get on.
You can text or ring me tomorrow if you like to run through it Pete !!
Post by petehodges on Jan 1, 2014 23:21:48 GMT 1
Possibly the loom you bought is the problem. Right, so the original clock loom is still in the kidney clocks. Plug the kidney clocks into the LC2 loom and check that every bulb lights up what it should. Let me know how you get on. You can text or ring me tomorrow if you like to run through it Pete !! Ok I'll have a look in the morning cheers mate
Post by Shytalk on Jan 2, 2014 19:10:02 GMT 1
Spent a few hours in shed tonight and almost there with clocks I,ve used lc2 loom fitted in lc clocks Just one problem really the high beam light indicator on clocks stays on the lights are fine just clock light stays on Do I have to the clocks advice please lads ? Is it as simple as you have plugged a backing light into the main beam light hole?
