Post by Deleted on Oct 27, 2005 13:04:13 GMT 1
Hi, I have a 4LO I am restoring but have no key for the steering lock, does anyone know how I can get one or a complete lock & keys? thanks ? ???
Post by Norbo on Oct 27, 2005 18:10:16 GMT 1
Its hard to get a compleat set theys days. Even when i brake one they arnt all the same you will be lucky to get a full set. If you take your ignition anf fuel cap and stering lock to a lock smiths he can ajust them to use 1 key dont know how mutch it is but its not loads .
Post by Deleted on Oct 27, 2005 18:55:39 GMT 1
Cheers all for your replies,but the steering lock is not on the ignition switch but on the frame headstock and looks like a small single sided key hole, any other ideas most appreciated.
Post by Norbo on Oct 28, 2005 22:12:21 GMT 1
The head stock lock only uses the first 3 runs on a key so if you took the bike to a locksmith he could take the internals of and refit after agusting it for the key you have I cant realy think of anything elce to help as you cany remove it from the bike.
Post by Deleted on Oct 29, 2005 9:58:52 GMT 1
Thanks Norbo, will try this once restoration complete as I can't be bothered to carry the frame to locksmiths !!!
Post by Norbo on Oct 29, 2005 22:11:44 GMT 1
Thanks Norbo, will try this once restoration complete as I can't be bothered to carry the frame to locksmiths !!! :DLOL
Post by Norbo on Oct 30, 2005 21:38:42 GMT 1
Hi jim hows it going . I think he could remove the internals but i think it would fall apart well it would if i did it any way be ok for some one elce
Post by vinze187 on Nov 4, 2005 7:41:45 GMT 1
Hi jim hows it going . I think he could remove the internals but i think it would fall apart well it would if i did it any way be ok for some one elce a bit heavy handed are we mate lol
