Post by copper99 on Dec 18, 2013 1:10:01 GMT 1
Been offered some 4LO genuine brake discs which have been bead blasted, not just the centres but in error, this company did the whole disc..I havent seen the discs themselves as yet, seller states discs still within width/wear specs
Im interested in them but will this blasting have affected the intergrity or braking performance of the discs!
TIA
Post by jon on Dec 18, 2013 8:59:56 GMT 1
I cannot comment from experience with discs, but would think they will be fine.
You say bead blasted (as opposed to sand or shot) so it should not of effected the surface much at all.
What I can say is that I had a lambretta hub chromed once. They must have blasted it as the first stage as the drum liner was uniformly pitted when it came back. I can honestly say it worked better, although I don't know the physics behind it.
Post by stfocus on Dec 18, 2013 9:11:09 GMT 1
U will be ok as i did mine and thay r fine
Post by badger1 on Dec 18, 2013 9:31:41 GMT 1
Did all of mine before I painted the centres. No problems there.
Post by calum64 on Dec 18, 2013 10:13:26 GMT 1
I did mine then polished up the disc before painting the center
Post by bazzer5115 on Dec 18, 2013 11:18:17 GMT 1
I"ve done a few in the past,they will be fine,in a hundred miles you will not know they been done
Post by copper99 on Dec 18, 2013 12:12:09 GMT 1
Thanks all...
