Post by thehut on Dec 1, 2013 22:42:30 GMT 1
can anyone tell me if this crank seal is in right way round. i took the stater off today and to me it has not been put in right way round. and it does not show you in manual.
Post by nikfubar on Dec 1, 2013 22:56:52 GMT 1
Yup right way round. As a general rule seal springs face the wet side
Post by thehut on Dec 2, 2013 1:06:57 GMT 1
yea but its facing dry side here. the spring is on outside as you are looking at it
Post by nikfubar on Dec 2, 2013 8:45:22 GMT 1
In that case it's the wrong way round, hard to see on the IPhone
paulo
Post by paulo on Dec 2, 2013 9:38:56 GMT 1
I'm sure this seal has a double sealing lip design to the crank surface. When I stripped both of my motors down I found the seal fitted different on each motor, so none the wiser. Think it's only the Rhs seal which is the important one - will have a look through my Yam book as that's what I had to do when I built mine up. If it's running Ok , then rebuild and enjoy before the snow comes.
Post by Norbo on Dec 2, 2013 9:49:04 GMT 1
As all ready mentioned crank seals are a double spring so this side can be fitted ether way round its only the other side that should be fitted with the castle side facing the bearings
Post by muttsnuts on Dec 2, 2013 9:57:28 GMT 1
that is the right way round, as Norbo has stated, the crank seals have a spring on either side and are a double lip seal, however, for reference, that seal is a genuine Yamaha one and the grean/yellow line that you can see on the outer edge denotes that faces outwards (to the stator), if you look verey closely on genuine seals you will see that one of the lips on the seal has a very fine red line going round it, that is the side that goes to the inside of the crank cases.
Either way, that seal is fine, its the other side you can't afford to get wrong
HTH
higgsy
Post by higgsy on Dec 2, 2013 9:58:54 GMT 1
Yep, the stator seal is universal, some have more of a bigger gap on one side, I fit the bigger gap to the outside, no reason other than it seems more logical Captain
If a seal has a spring on one side it normally goes to the wet side to help contain the pressure
If a seal has 'castles' then they go towards a bearing
bruno2
Post by bruno2 on Dec 2, 2013 9:58:55 GMT 1
Looks ok to me.
Post by thehut on Dec 4, 2013 22:06:12 GMT 1
thats ok then glad to hear that cheers
