Post by petehodges on Dec 1, 2013 13:07:05 GMT 1
Hi all Got an lc with metalax swing arm in Any know where I can get a good padlock stand as last two I've brought are proper shit They all move then start scratching up my all speeds or is there something else better out there cheers pete
Post by LC_BOTT on Dec 1, 2013 15:04:32 GMT 1
Post by petehodges on Dec 1, 2013 20:12:45 GMT 1
Yes mate I these on there just worried they don't lift very high
Post by oldelsieboy on Dec 1, 2013 20:19:50 GMT 1
I have one of these, lifts my Street Triple no problem. You will need to somehow attach some bobbins to your swingarm tho' OEB
Post by petehodges on Dec 1, 2013 22:07:56 GMT 1
I have one of these, lifts my Street Triple no problem. You will need to somehow attach some bobbins to your swingarm tho' OEB That's the thing is easy to add bobbins onto the arm ? Don't want too fook it up
Post by oldelsieboy on Dec 1, 2013 22:35:34 GMT 1
I have one of these, lifts my Street Triple no problem. You will need to somehow attach some bobbins to your swingarm tho' OEB That's the thing is easy to add bobbins onto the arm ? Don't want too fook it up You will need to get some threaded mounts welded to the bottom edge of the swing arm. OEB
Post by petehodges on Dec 1, 2013 23:09:04 GMT 1
Where best too get this done I take I can't thread them in to the arm ?
higgsy
Post by higgsy on Dec 2, 2013 10:01:54 GMT 1
Harris alloy. I've used everything else with varied results. We have six of them in the shop for customers bikes, says it all really, and you can get them with cups or bobbin hooks
Post by rich on Dec 2, 2013 11:04:07 GMT 1
Hi, I use the Biketek alloy paddock stand and it works great. I bought mine from 2wheeljunkie. I made a couple of threaded mounts, then marked out where I wanted them mounted and a local ally welder welded them on for £20 or so.
matt7
Post by matt7 on Dec 3, 2013 8:51:27 GMT 1
Abba stand = made adapters that bolt onto footrest mount points on frame
Post by petehodges on Dec 4, 2013 23:09:08 GMT 1
Thanks for replys lads keep them coming
Post by oldelsieboy on Dec 4, 2013 23:28:37 GMT 1
Thanks for replys lads keep them coming I think Rich has given you all the info you need & in pictures too. OEB
matt7
Post by matt7 on Dec 5, 2013 9:03:21 GMT 1
Thanks for replys lads keep them coming I think Rich has given you all the info you need & in pictures too. OEB You can remove the swing arm with my method
Post by lb on Dec 15, 2013 12:46:07 GMT 1
Rich, is that a metamech swinger with rgv 17 inch rim? Sorry o/p for going o/t....
