Post by bazzer5115 on Nov 26, 2013 23:28:46 GMT 1
Can anyboby explain what the rubbers do on my 350ypvs clutch drum do? Are they to damp any noise,are they required as one of mine looks a little damaged.Are there any advantages in fitting/not fitting them.Rebuilt many other bikes in the past and not seen them before? Cheers
Post by Bozzy on Nov 26, 2013 23:48:27 GMT 1
When I fitted upgraded race plates had to remove dampers or the set would not fit. A little noisier than before but no issues
db8888
Post by db8888 on Nov 27, 2013 0:43:06 GMT 1
they are v shaped cross section and when you pull the clutch I they help push the clutch plates apart to stop the clutch from dragging in my opinion they don't work as intended and are better left out............
