Post by bazzer5115 on Nov 26, 2013 23:18:19 GMT 1
Hi all, Just ordered a set of 34mm mikuni carbs for my tuned hybrid I am building.The front mounting spigot is 40mm and just wondered what inlet rubbers people are using.Billet alloy cost about £125,Moose racing oversize ones cost £86 each and v force cost even more,have I any other(cheaper)options. Also about to close crankcases up and not certain which way right side crankcase seal faces,old one was castle side in but a spare engine I have has the castle side out and if I remember reading here, the picture in Haynes manual is wrong.I am now getting confused.Gratfull for any help. Cheers
Post by rich on Nov 26, 2013 23:23:29 GMT 1
Seal fits castle side facing the bearing.
Post by mikee on Nov 27, 2013 18:40:26 GMT 1
Have a look for cagiva mito spares early ones have 35 mm carbs , might be a starter for ten
Mike
jools
Post by jools on Nov 27, 2013 23:11:38 GMT 1
Post by oldelsieboy on Nov 27, 2013 23:13:43 GMT 1
What is the bolt pattern dims vertical & horizontal you require?
OEB
Post by ianr4863 on Nov 27, 2013 23:36:48 GMT 1
Doesnt Norbo do them now on the trick bits page ?
Post by bazzer5115 on Nov 28, 2013 23:27:09 GMT 1
Just phoned the suppliers of the moose racing oversize inlets and the price they gave me were for two PAIRS as I asked for two(meaning one pair)so the price not too bad!So will go for them or may stretch to a pair of billet ones,spent so much on this hybrid I cannot cut corners now!
Post by ianr4863 on Nov 30, 2013 9:05:29 GMT 1
There are some manifolds , blocks and reeds on ebay right now for 34mm Mikunis . Search YPVS 350 reed blocks . Starting price £40 .
higgsy
Post by higgsy on Nov 30, 2013 10:25:13 GMT 1
34mm Mikunis will fit into the stock YPVS inlets with some WD40 and swearing. Once in the rubbers swell to the size, done a few like this with no noticeable problems.
