Post by efftwo on Nov 25, 2013 22:45:23 GMT 1
F2 neutral indicator (green) light sometimes doesn't work. What is the most likely culprit? Switch? I have wiggled the wires with no obvious result.
bngt
Post by bngt on Nov 26, 2013 0:12:33 GMT 1
Yes, or the connection to the switch.
Post by Tone on Nov 26, 2013 8:46:44 GMT 1
If you disconnect the single Blue wire at the neutral switch and touch it on the crankcase with the ignition on does your neutral light work? If it comes on then it is the switch. Could also be the Blue wire broken especially where it goes through the small D shaped grommet between the rotor and front sprocket.
