Post by brownsauce on Nov 25, 2013 10:54:56 GMT 1
Does anyone know how to remove the seat lock barrel without a key? It a 250lc by the way.
Post by Trubrit on Nov 25, 2013 10:58:46 GMT 1
Take It Out From The Back .. There Is A Little Retaining Lug You Have To Press In With A Small Screwdriver .... Watch The Bits Don't Go Flying When You Pull It Out ......
Dave
Post by oldelsieboy on Nov 25, 2013 11:03:37 GMT 1
Take It Out From The Back .. There Is A Little Retaining Lug You Have To Press In With A Small Screwdriver .... Watch The Bits Don't Go Flying When You Pull It Out ...... Dave Insert the key before you remove the barrel , it should keep the tumblers intact. OEB
Post by Trubrit on Nov 25, 2013 11:28:53 GMT 1
He Aint Got The Key........
Post by rich on Nov 25, 2013 11:32:19 GMT 1
He Aint Got The Key........ Yeah come on OEB, pay attention!
Post by oldelsieboy on Nov 25, 2013 11:45:00 GMT 1
He Aint Got The Key........ Yeah come on OEB, pay attention! Ooops OEB
Post by brownsauce on Nov 25, 2013 14:05:47 GMT 1
Thanks lads I'll give it a try, let you know how I get on ;-)
Post by ulsta on Nov 25, 2013 17:11:30 GMT 1
Take It Out From The Back .. There Is A Little Retaining Lug You Have To Press In With A Small Screwdriver .... Watch The Bits Don't Go Flying When You Pull It Out ...... Dave Insert the key before you remove the barrel , it should keep the tumblers intact. OEB You might be able to use a different key, but will need to jiggle it in and out to get each tumbler into position as you extract the lock. Each of the tumblers has a tiny spring that can launch itself and the tumbler into the furthest, darkest, most inaccessible place, never to be found again if you don't have a key (or something else) in the lock to keep them captive.
Post by shaunthe2nd on Nov 25, 2013 17:26:48 GMT 1
sounds like you had a bad experience in the past ulsta! does Norbo provide therapy for this sort of thing? lol
Post by brownsauce on Nov 26, 2013 11:11:20 GMT 1
Got the lock out and had a key made to fit made a small brass bush to take the play out of the seat lever, the only other thing is there is no return spring for the barrel. Should there be one if so were if anywere can I get one?
Post by JonW on Nov 27, 2013 1:23:03 GMT 1
Any spring will do if you can get it to fit, just try various ones you have in your spares, its nothing special as such.
