Post by gazilla on Nov 24, 2013 23:22:46 GMT 1
I seem to be using a high amount of 2 stoke.about 1 tank to 2 tanks of petrol.seems far more than when i owned my last one 20 years ago and if is high is it just a matter of adjusting oil pump?
Post by stfocus on Nov 24, 2013 23:38:28 GMT 1
R u on semi or fully 2 stroke oil as I get about 2 and a half tanks and I run semi
Post by AndyYam on Nov 25, 2013 7:10:29 GMT 1
Check your oil pump settings and check for leaks in the oil lines and bottle. My f2 had a rubbish cap and the oil was sloshing out the top, running down the lines onto the engine and dripping off the bottom. Thought it was gearbox oil at first.
Post by arrow on Nov 25, 2013 19:22:01 GMT 1
There could be a few things going on here. If you ride full chat all the time the pump will flow the equivalent of around 20:1. I have seen two pumps lately that did not have the large washer fitted to the end of the plunger shaft. This would also give very high oil consumption. Can you post a photo of the pump showing the gap with the plunger all the way out? It might just have a very big gap.
