Post by thehut on Nov 24, 2013 15:01:11 GMT 1
hi my lc350 was running fine last time i used it. bout a month ago. came to start it and dont want to know. it fired once then its just dead no spark at plugs. put another cdi in plugs had spark. tryed to start it again same thing fired once now dead again no spark. so looking like it blew another cdi. any ideas what can make it do this. iv checked kill switch and tryed different plugs. still nothing.
Post by muttsnuts on Nov 24, 2013 18:10:24 GMT 1
um, could be the windings in your stator going to earth, is it in a damp garage at all, damp weather/cold air will find any weakness in coils/windings, also, you checked your pickup, have you tested them for their resistance readings etc ?
Post by thehut on Nov 24, 2013 19:04:17 GMT 1
the stator was rewound before i baught it. iv checked picup 78.6. but my meter dont cant check the rest as meter has not got setting it says to put it on. it will be damp in my garage. is there any check for cdi unit to see if it has blowing it. no point keep buying them if stator just going to blow it.
Post by thehut on Nov 27, 2013 1:40:04 GMT 1
right got a meter to check stator windings. the pulser pick up whit/red to black wire 79.2 the windings red ro brown 11.8 and brown to black is 258.3. let me know what you think as looks like this stator is no good.
Post by steeley on Nov 27, 2013 6:42:56 GMT 1
hi,your source coil is out of spec red/brown should be 5.1 you have 11.8. try this chap for the repair R.E WILLIAMS alternator specialist 01626772791.
Post by thehut on Nov 27, 2013 20:22:39 GMT 1
ok cheers. have you used them before. as this one been rewound and not lasted long.
Post by bare on Nov 27, 2013 20:32:29 GMT 1
Not every rebuilder is any good at it. Could you not simply find and fit a used 4lo stator??
Post by thehut on Nov 27, 2013 21:13:45 GMT 1
thats what i might do yet. as westcounty windings. did this one and they in all the mags. its just finding a good one
Post by steeley on Nov 28, 2013 6:29:09 GMT 1
hi yes I have used mr Williams before he is very good quick turn around. had my 350lc stator repaired by him ,a fixing bolt came out and took the pick up coil out sent it off on the tue/had it back for the fri to fit on the sat.sent a ts 250 stator off which he checked and said was ok and thought that there was a problem with the bikes wiring and could I just cover the cost of posting. local with a ktm had stator problem he sent it off to him and he sorted it the guy was well chuffed he had thought for ages it was a carb problem.
Post by thehut on Nov 28, 2013 23:08:52 GMT 1
ok cheers were is he at.
Post by jmartin on Nov 28, 2013 23:36:38 GMT 1
DONT USE WEST COUNTRY WINDINGS ! . . . DONT CARE ABOUT THE ADS IN MAGS . . . I COULD PUT MY AD IN A MAG BUT IT DONT MEAN I COULD RE WIND A STATOR . . . USED TO SAY BAKED BEANS ON THE BUSES BUT THEY DIDNT SELL THEM ! HAD A STATOR WOUND BY THEM FOR A BETA TRIALS BIKE . . .FITTED IT . . . THE B%STARD WOULD NOT START . . .AFTER MUCH CHECKING OUT TURNS OUT THE STATOR WAS STILL FAULTY. CALLED THEM UP, DIDNET REALLY WANT TO KNOW ABOUT HAVING IT BACK FOR A SECOND TIME, JUST PAID ME MY MONEY BACK. OBTAINED AND FITTED A GOOD SECOND HAND UNIT, BIKE BURT INTO LIFE AND NEVER MISSED A BEAT AFTER. I WOULD ALWAYS PREFER TO USE A GOOD SECOND HAND ORIGINAL UNIT AS RECONDITIONED ARE ONLY AS GOOD AS THE GUY THAT HAS DONE THE WORK !
RANT OVER . . . .
Post by jmartin on Nov 28, 2013 23:37:51 GMT 1
WOULD NOT LET THEM WIND MY CLOCK UP . . . . . !
RANT OVER . . . AGAIN . . .HONEST !
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Nov 29, 2013 18:41:52 GMT 1
don't laugh I had the same problem turns out the woodruff key had sheered just my two peneth
Post by gillybobs on Nov 29, 2013 19:20:24 GMT 1
I had a similar problem and it was the exciter coil on the out side of the fly wheel. It had corroded between the stator plate and the coil. I just unscrewed the coil, cleaned both surfaces put it back and my bike been fine ever since . Might be worth a try before sending any parts off for refurb.
Post by thehut on Nov 29, 2013 19:49:16 GMT 1
dont think it be corroded as the lad i baught bike off had it rewound before i baught it. bike has only done about 200 mile. i will have a look tho. bike has never realy had a good spark since i baught it.
Post by steeley on Nov 29, 2013 20:28:54 GMT 1
hi R.E WILLIAMS alternator specialist ,29 colman avenue teignmouth devon tq 14 9 du 01626772791 .
Post by thehut on Nov 29, 2013 22:08:41 GMT 1
cheers m8t
Post by gillybobs on Nov 30, 2013 20:47:45 GMT 1
The other thing I did in my infinite wisdom at a later date was that I put thread lock on the screws for the stator coils and this works like an insulator and stopped the bike sparking again. Just something else to look at.
Post by thehut on Nov 30, 2013 21:47:07 GMT 1
ok thanks for that
