Post by anderoo on Nov 15, 2013 21:02:37 GMT 1
Hi. Does anybody know if standard exhausts can be modded to make them less restrictive.
Post by midlifecrisisrd on Nov 15, 2013 22:01:39 GMT 1
Post by marsbar350 on Nov 15, 2013 22:19:26 GMT 1
a good decoke really helps
Post by steve h on Nov 15, 2013 22:36:23 GMT 1
Yes. But it means cutting them in half and removing some metal gauze wadding. There are some pictures of this gauze in situ on here somewhere. This was done back in the day in production racing. Don't know how much of a difference it makes on its own, as it was done with all the other mods. And Mars's suggestion is spot on
Post by marsbar350 on Nov 15, 2013 23:08:37 GMT 1
you could always check that the right exhausts are fitted to the bike restricted or 250 pipes or both
Post by steve h on Nov 15, 2013 23:36:42 GMT 1
If you've chopped them in half, 250 pipes can be turned into 350 pipes The wrong paint blob wont slow the bike down
Post by marsbar350 on Nov 15, 2013 23:39:10 GMT 1
**seholes in the baffle plates will
Post by steve h on Nov 16, 2013 23:19:17 GMT 1
ken007 in Aus has some pics on here somewhere showing restricted German 250 pipes turned into 350 pipes. The baffle plates met with a drill
