Post by dusty350 on Nov 15, 2013 19:02:20 GMT 1
Hi Looked at this Metmachex arm today, albeit very briefly. Is this arm meant for a Ypvs wheel ? Check the inside of the right spar- is this for a Ypvs caliper carrier ? Can you still get the spindle adjusters ? Regards Dusty
Post by oldelsieboy on Nov 15, 2013 19:10:48 GMT 1
Hi Is this arm meant for a Ypvs wheel ? Check the inside of the right spar- is this for a Ypvs caliper carrier ? Regards Dusty Yep, should measure 210mm across the wheel spindle (internal) OEB
Post by dusty350 on Nov 15, 2013 19:24:25 GMT 1
Cheers nigel what do you think irs worth as it is ?
matt7
Post by matt7 on Nov 15, 2013 19:56:00 GMT 1
Cheers nigel what do you think irs worth as it is ? Defo dependant on seller !!!
Post by dusty350 on Nov 15, 2013 20:11:26 GMT 1
Haha
Post by oldelsieboy on Nov 15, 2013 20:26:34 GMT 1
Cheers nigel what do you think irs worth as it is ? Defo dependant on seller !!! Well "he" listed one recently for £386 ono, it must have been "useful to someone" because it sold for best offer. OEB
Post by rich on Nov 15, 2013 20:31:24 GMT 1
Wheel spindle and eccentrics are gonna cost too if they aren't with it.
Post by Shytalk on Nov 15, 2013 20:31:41 GMT 1
You'll be able to get the missing parts still from Metmachex, give them a call.
Post by rich on Nov 15, 2013 20:33:09 GMT 1
You'll be able to get the missing parts still from Metmachex, give them a call. Yes you can but they ain't gonna be cheap!
Post by dusty350 on Nov 15, 2013 20:47:31 GMT 1
I was offered it today for £100 as it is. Didn't know if it was a good price or not. It's had some repairs and once they were dressed down and polished it would be a nice arm. Cost of the adjusters could be prohibitive though. I will think about it. Cheers fellas
Regards
Dusty
Post by botty on Nov 15, 2013 20:53:49 GMT 1
Is the internal on a ypvs arm wider than on a LC? Just inquisitive
Post by dusty350 on Nov 15, 2013 21:06:57 GMT 1
Hi, Lc is narrower by approx. 11mm if I remember right.
Dusty
Post by rich on Nov 15, 2013 21:53:19 GMT 1
The LC arm is 20mm narrower inside at the wheel end (YPVS 210mm, LC 190mm)
Post by dusty350 on Nov 16, 2013 10:12:39 GMT 1
Cheers Rich, Wasn't sure on the difference in widths. Remember having 11mm milled off my Ypvs caliper carrier to have it fit the Lc swing arm. Must have had some other mods but I cant remember what !! Dusty
