Post by Eyrey1 on Nov 9, 2013 1:44:49 GMT 1
anyone know of a shock off something like an r6 /fireblade that will go on an lc2 with minimal work ? ive been looking and the r6 ones dont look far off ! thanks in advance Gary
Post by dusty350 on Nov 9, 2013 9:54:42 GMT 1
Hi, If you check out the US forums, a lot of guys have used R6 shocks. You need to grind out an area on the top frame mount for the shock body to clear it, but simple enough. They are relatively cheap on ebay too.
Dusty
Post by rich on Nov 9, 2013 12:03:27 GMT 1
I used a 600 Fazer (98-03) shock on mine. You have to change the lower fitting from a fork to eye from an old YPVS shock but it otherwise goes straight in and works well. Raises the back very slightly too which always helps.
