Post by martyngsxr1 on Nov 7, 2013 20:42:50 GMT 1
okay then the flasher relay on my lc2 is playing up now done a few searches and ypvs flasher units are 2 pin mine is a 3 pin now the lc is a 3 pin could i use that or will i be okay with the 2 pin ypvs one
cheers martyn
Post by oldelsieboy on Nov 7, 2013 21:09:01 GMT 1
okay then the flasher relay on my lc2 is playing up now done a few searches and ypvs flasher units are 2 pin mine is a 3 pin now the lc is a 3 pin could i use that or will i be okay with the 2 pin ypvs one cheers martyn Doesn't the flasher have to be 3 pin for the self cancelling to work? OEB
Post by martyngsxr1 on Nov 7, 2013 21:18:48 GMT 1
I don't know that's why I was asking
Post by oldelsieboy on Nov 7, 2013 21:35:28 GMT 1
How many wires does it show on the wiring diagram?
OEB
Post by martyngsxr1 on Nov 7, 2013 21:52:27 GMT 1
Haven't looked to be honest just looked at the wiring diagram in the Haynes manual and the wiring is the same on the lc2 n and f model it states brown brown/white and yellow/blue
Post by shaunthe2nd on Nov 7, 2013 22:24:00 GMT 1
okay then the flasher relay on my lc2 is playing up now done a few searches and ypvs flasher units are 2 pin mine is a 3 pin now the lc is a 3 pin could i use that or will i be okay with the 2 pin ypvs one cheers martyn if you have the wrong bulbs in, or one bulb isn't working, or is different to the others, then this often looks like a flasher unit fault. its worth checking before you splash your cash.
