chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Nov 7, 2013 18:45:01 GMT 1
I have two temperature senders which came out of different LC's both fit both work however as you can see they have different numbers and are different in circumference which one is correct or are they both correct/wrong your thoughts please
Post by rich on Nov 7, 2013 18:51:13 GMT 1
My thoughts are does it matter if they both fit and work fine? The numbers could mean anything - different manufacturer, batch code, date code etc
Post by winnerevo1 on Nov 7, 2013 18:58:53 GMT 1
The spade terminal on the R/H one is the correct type (left is not). All of the proper LC ones I've seen have a green top, I've not studied the numbers, I would have to check all of the ones that I have.
I have a NOS one that has 9T & NS stamped on it but I haven't checked any of the others to see if there is any variation on the numbers.
chorltoncumrd
Post by chorltoncumrd on Nov 7, 2013 20:37:35 GMT 1
My thoughts are does it matter if they both fit and work fine? The numbers could mean anything - different manufacturer, batch code, date code etc thanks for that m8, I just did not want to put them for sale on a well known auction site and give wrong info
chorltoncumrd
Post by chorltoncumrd on Nov 7, 2013 20:39:28 GMT 1
if you can identify the r/ side as correct can you tell me what the l/side sender fits
Post by stfocus on Nov 7, 2013 20:46:58 GMT 1
My thoughts are does it matter if they both fit and work fine? The numbers could mean anything - different manufacturer, batch code, date code etc thanks for that m8, I just did not want to put them for sale on a well known auction site and give wrong info Hi pal I need one how much do u want for the one on the right
chorltoncumrd
Post by chorltoncumrd on Nov 8, 2013 18:00:40 GMT 1
stfocus you have pm
Post by stfocus on Nov 8, 2013 20:36:37 GMT 1
Thanks pal I have one now
chorltoncumrd
Post by chorltoncumrd on Nov 8, 2013 23:40:57 GMT 1
Thanks pal I have one now no worrries
