Post by calum64 on Nov 7, 2013 18:14:28 GMT 1
What goes on this bracket between the chassis rails under the tank.
Post by 47x on Nov 7, 2013 18:20:43 GMT 1
throttle cable isn't it???
Post by oldelsieboy on Nov 7, 2013 18:30:02 GMT 1
What goes on this bracket between the chassis rails under the tank. Nothing. OEB
Post by 47x on Nov 7, 2013 18:34:01 GMT 1
isn't there a rubber sleeve on genuine throttle cables that slides on to this bracket nige???
Post by calum64 on Nov 7, 2013 18:37:24 GMT 1
As long as it's nowt electrical because I was wondering why I had a bracket and no more plugs to put anything into. Cheers.
Post by rich on Nov 7, 2013 18:39:07 GMT 1
Nothing. Throttle cable junction box clips on under the airbox
Post by 47x on Nov 7, 2013 18:40:20 GMT 1
oh yeah.^^^wat he sez..^^!!!
Post by oldelsieboy on Nov 7, 2013 18:52:09 GMT 1
As long as it's nowt electrical because I was wondering why I had a bracket and no more plugs to put anything into. Cheers. Some people locate the indicator self cancelling unit there instead of behind the steering head. OEB
Post by farmboy on Nov 7, 2013 22:29:19 GMT 1
I put my self cancelling unit there, I had a spring hoop clip still on the airbox as Rich says where I cliped my genuine throttle cable to . I am not 100% sure if that right, you seem to end up with 3 wiring plugs in that area too. Oh make sure you clean some more of the paint off from the coil mounting holes to mount the coil and the earth wire on the harness.
Post by roughlad on Nov 10, 2013 22:40:38 GMT 1
It is for the indicator self cancelling unit
Post by winnerevo1 on Nov 10, 2013 23:28:18 GMT 1
It is for the indicator self cancelling unit No it isn't. The self cancelling unit fits further forward on the tab behind the headstock.
