Post by stfocus on Nov 6, 2013 20:20:17 GMT 1
how can u tell if your ignition is genuine or patten one thanks
Post by loctite on Nov 6, 2013 20:59:22 GMT 1
the key for one mate
Post by stfocus on Nov 6, 2013 21:14:43 GMT 1
Thanks pal but if new keys have been cut thay don't say Yamaha on any more
Post by loctite on Nov 6, 2013 22:38:41 GMT 1
good point I think the after market ones have a plastic barrel casing on but then again ive got one that's not got the plastic case but metal,
Post by steve h on Nov 6, 2013 22:53:06 GMT 1
Compare what you've got with a gen one! I'm only in Brig
Post by stfocus on Nov 6, 2013 23:21:26 GMT 1
Compare what you've got with a gen one! I'm only in Brig Thanks steve Its i just got one as gen one but i have my doudt about it i have a patten one and it look the same just the key is longer
Post by midlifecrisisrd on Nov 7, 2013 9:03:45 GMT 1
As far as I am aware the key is a different style on the pattern ones I've seen.
A pattern key would not fit in the genuine lock ( cap or seat )
Post by Norbo on Nov 7, 2013 9:17:32 GMT 1
Most Patten keys don't have yam on them . some do but most don't so depending on whats on the key that should tell you
Post by ogri211 on Nov 7, 2013 15:04:32 GMT 1
Check if it has snap bolts holding it on
