Post by martyngsxr1 on Nov 5, 2013 23:16:24 GMT 1
Looking at a 31k swingarm to go into the lc2 now from the pictures I've been sent the 31k adjusters sit inside the swingarm is this correct and does the 31k fit the lc2
Post by rich on Nov 6, 2013 0:16:53 GMT 1
Assuming by 31K you mean the box section arm fitted to the F1/N1 onwards? The LC2 arm has thin ends and old type adjusters same as an LC and the later box section arm has the ones that sit inside the arm. Apart from that the rest of the arm is the same so any arm will fit any model of YPVS. Worth noting that the wheel spindle is longer on the box section arm and the F1/N1 standard exhausts have cutouts to clear so if you fit a later arm to an LC2 then the spindle might hit the exhausts.
