Post by martyngsxr1 on Nov 5, 2013 10:08:23 GMT 1
been offered some gsxr400 bits i.e front and rear end not to sure what model there off as i havent had a look as of yet has anyone done this upgrade
cheers martyn
Post by midlifecrisisrd on Nov 5, 2013 15:26:52 GMT 1
If GSXR 400 GK76 it is almost identical to RGV 250 USD front end.
Assume rear will be similar to RGV without the brace.
Post by Yogi on Nov 5, 2013 15:41:23 GMT 1
You have to shorten the front where the pivot bolt goes through by 7mm on each side. I used the gsxr roller bearing outer cups and pressed the rd roller bearings into them.fitted perfect but you have to grind the lip off the gsxr bearing and take out the rollers to get them in. Front end bolts on with the spacer same as rgv. Quite wide though you have to mod the footrest hangers and back brake switch too. Then I gave up and used an rgv braced arm instead?
Post by Yogi on Nov 5, 2013 15:44:50 GMT 1
The bike in my avatar as a gsxr400 front and back
