Post by ivymike on Nov 3, 2013 23:23:15 GMT 1
hi, what do people use to connect these carbs to standard 350 ypvs airbox?
Post by jessy03 on Nov 3, 2013 23:42:03 GMT 1
You can use the std rubbers, just warm them up first in some hot water then stretch them over. Jess
Post by rich on Nov 4, 2013 0:01:36 GMT 1
As above you can use the standard YPVS rubbers but they are a swine to fit over the bigger carbs. Easiest way is to fit the rubbers to the carbs and then the carbs to the bike.
Post by midlifecrisisrd on Nov 4, 2013 9:10:04 GMT 1
As above you can use the standard YPVS rubbers but they are a swine to fit over the bigger carbs. Easiest way is to fit the rubbers to the carbs and then the carbs to the bike. Ditto Steve
Post by johnlc on Nov 4, 2013 10:16:32 GMT 1
Would it be easier with the kr1s rubbers if you can get them
Post by rich on Nov 4, 2013 11:22:44 GMT 1
I have KR1S rubbers on my LC hybrid and they have a double lip similar to the LC rubbers so fit the airbox perfectly, although they are still a bugger to fit due to having a long trumpet that goes into the airbox.
I don't think they would fit the YPVS airbox as from memory the rubbers fit over stubs?
Post by ivymike on Nov 4, 2013 22:14:58 GMT 1
thanks for that any suggestions on jetting on pre mix @ 33:1
